1994 Dodge Ram 1500 4x4 20 min cool down before restarting
Old Nov 7, 2023 | 10:41 PM
Gasser's Avatar
Gasser
Default 1994 Dodge Ram 1500 4x4 20 min cool down before restarting
Truck will run, but once I shut it off. It doesn’t want to start back up. I have to wait 20 minutes or less for it to cool down to restart.
my second problem is my overdrive keeps blowing its fuse?
Old Nov 8, 2023 | 10:56 AM
AtomicDog's Avatar
AtomicDog
Post
Does the truck starter turn over at all during restart? Trying to narrow down where the issue may lie, as several things could cause this type of issue on this elderly vehicle.
As for the overdrive blowing fuses, take a look at the wires going into the transmission to see if they may be frayed/bare and causing the short.
Old Nov 8, 2023 | 04:45 PM
Gasser's Avatar
Gasser
Default 20 min cool
It will crank and crank , doesn’t want to start up until . I have to wait 20 min or less to cool down, then it will start up again
Old Nov 8, 2023 | 05:57 PM
AtomicDog's Avatar
AtomicDog
Have you plugged in an ODB1 scanner during the times it won't crank to see if you have any pending or stored codes? The last time that happened to me was the crank sensor, but your issue may be different.
Old Nov 8, 2023 | 08:04 PM
Gasser's Avatar
Gasser
Default 20 min cool
The way you do mine is counting the check engine light. My truck doesn’t take those crankshaft sensor number popped up.
Old Nov 9, 2023 | 09:03 AM
Keith_L's Avatar
Keith_L
Crank sensor or ECT would probably be my first suspects. I've had TPS cause similar symptoms on OBD-I EEC-IV Fords, so that might be my third suspect
Old Nov 9, 2023 | 09:22 AM
Gasser's Avatar
Gasser
Just put a new ECU in it. But still wants to not start when at temperature when I shut it off. The only thing I have not replaced is my crankshaft sensor
Old Nov 9, 2023 | 09:28 AM
Get a genuine mopar crank sensor. These trucks don't play nice with the aftermarket fellers.
Old Nov 9, 2023 | 11:41 AM
AtomicDog's Avatar
AtomicDog
Lightbulb
I can attest to this after running a replacement Borg-Warner crank sensor for a couple of years, then having to deal with weird behavior like the truck not wanting to start at random times or cutting off in traffic at low idle at a stop light. Finally, after the truck cut off while driving down a country road and displayed a code referencing the crank sensor (had my scanner with me, as the truck was cutting off and not displaying a code previously), I replaced the crank sensor with a genuine MOPAR crank sensor and all of those issues went away.
