Fuel Gauge
Old Dec 14, 2023 | 06:07 PM
Lone Ranger Roy's Avatar
Lone Ranger Roy
Default Fuel Gauge
My fuel gauge is broken. I want to ask if anyone knows of something that can go down into the fuel tank from where the fuel door is? I tried a few different things, nothing gets past I'm guessing the bend in the pipe.
Old Dec 14, 2023 | 06:38 PM
AtomicDog's Avatar
AtomicDog
What year truck are you dealing with and what engine size (gas or diesel)? The fuel sending unit is a part of the fuel pump, so if the fuel sending unit is bad, you're going to need to drop the fuel tank to address it.
Old Dec 15, 2023 | 03:33 PM
Lone Ranger Roy
Truck is a 1995 dodge ram 5.9 diesel. Probably the sending unit in the tank. While I procrastinate about dropping the tank, I tried getting a marshmallow toasting stick down the tank. No way, maybe can't get anything down the tank to prevent syphoning, Trying to put something down the tank for a measurement is not something I would usually do. I thought the stick would go down easier. I fill it up and it's usually around a 1/2 tank. I don't want to run out of fuel. At 1/12 tank I'm constantly mixing new fuel with old fuel. I'm going to have to drop the tank or bring into a shop.
Thank you Adam Dog.
Old Dec 15, 2023 | 03:34 PM
Lone Ranger Roy
Sorry, Thank you Atomic Dog.
Old Dec 15, 2023 | 05:15 PM
You should have a pretty good idea of your fuel mileage (I will NOT call it economy..... just doesn't fit with these trucks. ) so, you can 'best guess' your range, give yourself a comfy margin (50 miles or so?) and fill up when you are getting close.
Old Dec 16, 2023 | 12:24 PM
Moparite's Avatar
Moparite
There are stick on sensors used for RV tanks that will give you a idea where the level is. Not sure if they will work below freezing temps. https://www.truegether.com/listing.h...9-f4403f1cfb9d
Old Dec 17, 2023 | 07:32 PM
Lone Ranger Roy
I should have thought of that. @ 20 miles to a gallon. I'll use 15 mph see how that works out.
Thank you.
Old Dec 17, 2023 | 07:34 PM
Lone Ranger Roy
I'll look at stick on sensors that are used on RV's. Thank you for that. I'll let you know how that works.
Thank you.
Old Dec 20, 2023 | 08:04 PM
ddtmoto's Avatar
ddtmoto
Is your gauge plain dead or are you getting erroneous readings.?
