Leaf Spring Bushing Replacement
Howdy all,
I'm in the process of replacing all four of the leaf spring bushings and both of the shackles on my truck. I figured after a new transmission and a Redhead gear box what's 75 bucks in shackles and bushings and just dove in today. I purchased the Ruff Stuff bushings that were mentioned a few times on some of the older threads here and I'm a bit stumped on the installation process.
I have the old bushings removed and there appears to be a thin tubular piece of metal inside the leaf spring eye. Some of the install videos I watched removed this metal piece, some didn't, and those that did had a new metal cover around the new bushings they were installing. My question is, these Ruff Stuff bushings appear to be the correct sizes, so do I just push them in or do I have to remove and replace the metal part inside of the eye? If anyone has any experience with these bushings it would be greatly appreciated!
Thanks!
Thin tubular piece of metal inside leaf spring eye.
Thanks!
Nah, you don't want to get the metal hot enough for it to expand, that would likely do a number on the bushing when you installed them. If you can't squeeze 'em in there with something like a large pair of channel-locks, may have to get the steel sleeve outta there.
I'll have try with a channel lock tomorrow morning and report back. Is there any disadvantage to not having the metal sleeve other than, I imagine, a tad more exposure to the elements?
If the bushing fits well, I don't think it really matters one way or the other.
The following users liked this post:
Keith_L (01-18-2024)
Trending Topics
latkelarry (01-18-2024)
Yep OE rubber bushings come in a metal shell. Usually it's bonded quite well so I'm surprised you got the rubber out (short of using a blue wrench and inhaling lots of really good fumes) without also having the shell move.
If the new bushings don't fit, your options are to remove the shell or have a machinist turn down the new bushings to account for the wt (wall thickness) of the shell.
At this point the game was to get it back together with whatever I had around. I had some Tacoma leafs in my pile and at some point someone had installed poly bushings in the front eyes. I tapped them out but if I removed the existing Nissan metal shell they'd be too small, and if I left the shell the bushings were too large. I had to take about .100" off diameter and they fit well.
Granted, you can see the Nissan shell is a little mangled but it's WAY better than it was.
