crank no start
Old May 1, 2024 | 12:30 AM
DJGreco's Avatar
DJGreco
Originally Posted by Moparite
Is the fuel pump priming when you turn the key to on? Is the asd relay working?
My add relay works i checked it with the ohm reader. I do not audibly hear my fuel pump priming thought but it i don't get spark either so i figured it's tired into eachother.
Old May 1, 2024 | 03:41 PM
Do you see power at the coil, or injectors at initial key on? (you will only get it for a few seconds, so, two people pretty much required.
Old May 4, 2024 | 12:31 PM
oddone's Avatar
oddone
I had the same issue with my 95 1500 ended up being the pick up under the distributor cap though it was crank sensor and couldn't get anyone to figure it out till a friend's mechanic came out and figured out exactly what it was
Old May 4, 2024 | 04:02 PM
Moparite's Avatar
Moparite
The asd relay needs to supply power or nothing else will work. If you have power then look at the sensors,coil ect.
Old May 14, 2024 | 11:49 PM
DJGreco's Avatar
DJGreco
Yes there is power to my coil i checked today
Old May 14, 2024 | 11:50 PM
DJGreco's Avatar
DJGreco
so what needed replaced?
Old May 14, 2024 | 11:52 PM
DJGreco's Avatar
DJGreco
so when i checked my asd it was getting power and also i checked my fuel pump it is priming
Old May 15, 2024 | 07:52 AM
Is it still throwing the same codes?
Old May 19, 2024 | 11:58 PM
DJGreco's Avatar
DJGreco
I checked my injectors and they are not getting power.
Old May 20, 2024 | 06:29 AM
Moparite's Avatar
Moparite
Coil, injectors and 02's get power from the asd relay. Are you sure you checked the correct wires since you said it has power at the coil?
