2001 ram 1500 no overdrive
Old Sep 13, 2024 | 11:28 PM
Jw1424616's Avatar
Jw1424616
Default 2001 ram 1500 no overdrive
Hello, I’m a new member and I just purchased a 2001 ram 1500 4x4 with 130,000 miles and it won’t shift into overdrive, I know there are several posts about that on here, but they don’t answer my question. Which is how long will it last like this? Fluid looks good a little dark red maybe…. It has a code for torque converter/ overdrive solenoid I think. But I’m fine with driving it without overdrive. But I’m curious if this means the transmission is going out. Thank you for any advice
Old Sep 13, 2024 | 11:43 PM
dodgetruck2's Avatar
dodgetruck2
Overdrive no big deal, higher rpm on the highway, more throttle response, less fuel economy. The torque converter one might cause more issue, if its not going into lock up is free spinning all the time and that generates heat. Keep an eye on the trans temp 200*F is the general area you like it, similar to coolant temp, hot days or towing, hotter is acceptable, over 230-240 id be concerned though
you would need an aftermarket gauge to read trans temp, either analog or an OBD2 gauge pod will read off the PCM, however thats sump temp, not always the most accurate location for the hottest temps.
Old Sep 14, 2024 | 01:15 AM
Jw1424616's Avatar
Jw1424616
thank you, I do believe it’s locking up properly as my rpm’s drop 200 once I get to my desired speed. I’m not sure how to check the transmission temperature… maybe obd port?
edit: okay I didn’t finish reading your message… yes I’ll try the obd port
Old Sep 14, 2024 | 10:41 AM
Check engine lite on? Any codes? Is the O/D off lite in the dash on?
Old Sep 14, 2024 | 12:37 PM
Jw1424616's Avatar
Jw1424616
only a code for Tcc/OD solenoid. O/D liight is off
Old Sep 14, 2024 | 12:54 PM
Probably need to replace the O/D solenoid then..... Not too bad of a job, if a bit messy.
Old Sep 14, 2024 | 01:06 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would remove the connector at the transmission and make sure you have a good connection. You can add dielectric grease to the pins and that will give you better contact. Try this before replacing the solenoids. One question, you have a 46RE transmission.
Old Sep 14, 2024 | 01:13 PM
Jw1424616's Avatar
Jw1424616
okay thanks, I was looking into this direction
Old Sep 14, 2024 | 01:15 PM
Jw1424616's Avatar
Jw1424616
im not sure what transmission I have, the truck feels pretty heavy duty for whatever that’s worth, but I’ll try cleaning connections. Thanks
