Kegger intake short runners ?
Old Dec 22, 2024 | 11:03 AM
WASyL's Avatar
WASyL
Default Kegger intake short runners ?
I did a lot of research but didn't find anything.
I do want to shorten Kegger intake runners by half length, did anyone tried it before and tested on track or Dyno ?
Old Dec 22, 2024 | 11:28 AM
Hughes engines (or is it hughes performance??) has some dyno charts with various modifications of the kegger intake. Keep in mind though, that shortening the runners moves your power band up in the RPM range..... Which isn't really what you want if you actually use your truck AS a truck.....
Old Dec 22, 2024 | 11:49 AM
WASyL's Avatar
WASyL
I know that, but I will be running my Mag in 1950 Ply Business Coupe hot rod, just asking this question here as You guys have lots of knowledge which cannot be found elsewhere
Old Dec 22, 2024 | 12:01 PM
Ah, well, that's an entirely different kettle o' fish.
Might wanna look at the hughes air-gap instead then, or, if you get REALLY lucky, a Mopar M1 intake. (they came in both 2 and 4 bbl flavors.... 2bbls are rare, but, if you can find one, that's the one ya want. )
Old Dec 22, 2024 | 12:11 PM
WASyL's Avatar
WASyL
They are expensive and rather hard to find used, I try DIY or being cheap 😅 I will do it anyway but would like to see others experiences and results of such mods.
Old Dec 22, 2024 | 12:31 PM
I did the kegger mod on my 96 truck, cut the runners back about an inch or two, it did indeed move the powerband up, but, gave a bit more power above about 1500 RPM or so...... Check out the hughes site, see what they have done, you can likely get some ideas from them.
Old Dec 22, 2024 | 12:41 PM
WASyL's Avatar
WASyL
Will check that, thanks 👍
Old Dec 23, 2024 | 06:44 AM
Moparite's Avatar
Moparite
Might want to check out this.
Old Dec 24, 2024 | 02:29 PM
WASyL's Avatar
WASyL
These are still long runners, 1,5-2 inch cut is actually not much.
Old Dec 24, 2024 | 02:42 PM
It's enough to raise the power band a few hundred RPM, and extend it further up in the range as well.
