crank no start
Old Apr 19, 2025 | 10:01 PM
Demetrius 97sport's Avatar
Demetrius 97sport
Default crank no start
i have replace the distributor cap with the rotor and ignition pickup and crank sensor and ignition coil and ignition switch still a crank no start i checked the pcm even swapped it still no start and im getting 5.2 volts to all my 5 volts points on pcm pin outs been down for two weeks need help asap
Old Apr 20, 2025 | 06:55 AM
Moparite's Avatar
Moparite
What is the truck info? Any codes? Getting fuel and spark?
Old Apr 20, 2025 | 08:18 PM
Demetrius 97sport
no codes
Old Apr 20, 2025 | 08:55 PM
What are you driving? Engine? Trans? Etc..... Help us help you.
Old Apr 20, 2025 | 11:58 PM
Demetrius 97sport
1997 dodge 1500 sport 5.9 stock trans everything is stock
Old Apr 21, 2025 | 01:16 AM
AtomicDog's Avatar
AtomicDog
When you turn the key on prior to starting the truck, do you hear the fuel pump engage for a few seconds before turning off? Also, have you checked for fuel pressure at the fuel rail?
Old Apr 21, 2025 | 05:28 AM
Demetrius 97sport
the aso relay is clicking on and off i tried starting fluid but is has no spark so it wouldn’t help
Old Apr 21, 2025 | 06:16 AM
Moparite's Avatar
Moparite
You mean ASD relay, Have you tried swapping it out with the horn relay? Battery and connections good?
Old Apr 21, 2025 | 10:00 AM
97 won't have the pressure test port on the fuel rail, they were plastic that year......
If the fuel pump tests when you turn the key to on, but, you aren't getting any spark, likely bad crank sensor, or PCM.
Old Apr 21, 2025 | 12:47 PM
Demetrius 97sport
alright so what brank crank sensor is everyone getting i tried different ones already
