No start
Old May 20, 2025 | 08:07 PM
JohnathanG27's Avatar
JohnathanG27
Default No start
I've got a 1998 dodge ram 1500 5.9.
I'm a bit confused , I have power all the accessories turn on , I turn the key and not an single thing happens i had the starter tested it works , I had the battery tested twice ,one place says the battery needed replaced the other place charged it and says it held. I even hooked up jumper cables to it just incase and still nothing , I have new plugs and wires I have a new cap and rotor on it . Im not sure what it could be , I was kind of leaning towards the ECU but I need more input . I also put a computer on it and the only code it had was a ECT sensor(Engine Coolant Temperature ).Any Advice would be greatly appreciated.
Old May 20, 2025 | 08:29 PM
Does the engine roll over with the starter motor? If not, try starting in neutral.
Old May 20, 2025 | 08:34 PM
JohnathanG27
There's nothing not even a roll over ,or a struggle to start
Old May 20, 2025 | 08:39 PM
dodgetruck2's Avatar
dodgetruck2
I would look at the NSS like mentioned, try the gear selector in different positions and see if it makes a difference. Assuming Auto? if manual the clutch switches are junk, wire around it and see if there's a change, then replace as soon as you can
Old May 20, 2025 | 08:57 PM
JohnathanG27
its auto and putting it into another gear i got a crank no start
Old May 20, 2025 | 09:45 PM
JohnathanG27
If it dIsn't do anything in park but i get a crank no start out of park , would that mean the nss would be bad ?
Old May 20, 2025 | 11:05 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
Not necessarily. It could be that your shifter linkage has a shot bushing in it and/or it may be out of adjustment. This video may help -
Old May 20, 2025 | 11:10 PM
JohnathanG27
Originally Posted by AtomicDog
Not necessarily. It could be that your shifter linkage has a shot bushing in it and/or it may be out of adjustment. This video may help - https://www.youtube.com/watch?v=ThfO7dVC3oo
thank you I'll take a look at that too .
