Swapped the Fuel Pump...
Old Feb 20, 2006 | 01:26 PM
steve05ram360's Avatar
steve05ram360
Default Swapped the Fuel Pump...
I did the fuel pump swap yesterday... my problem is still there (major pinging under heavy load). The job took about 1.5~2.0 hours and was pretty easy. I did a writeup last night since everything was still fresh in my mind and submitted to the DIY fourm admin. with pics.
For all of you who are considering yanking the bed... do it as a last resort... dropping the tank was pretty easy. your biggest problem might be getting the strap bolts free, I soaked mine prior to dis-assembly and they came apart pretty easily.
All of this is great news though... that means my ~14.0 milage is a good number... I was thinking It was that good because the fuel pressure was dropping out slightly. that doesnt seem to be the case.
Old Feb 27, 2006 | 03:00 AM
steve05ram360
Default RE: Swapped the Fuel Pump...
Update... looks like the fuel pressure was dropping out... mpg is now around 12 or so...
Old Feb 27, 2006 | 03:37 AM
Socha_62's Avatar
Socha_62
City?
Old Feb 27, 2006 | 01:38 PM
steve05ram360
nope... 90% hiway... [sm=boohoo.gif]
It explains alot though... milage slowly started creeping upwards.
Old Feb 27, 2006 | 03:03 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
I hate to say this, but that's why I plan on replacing all three at once. I always look to head off Mr. Murphey.
Old Feb 27, 2006 | 03:04 PM
steve05ram360
ORIGINAL: VWandDodge
all 3?
Old Feb 28, 2006 | 12:03 AM
ryans590's Avatar
ryans590
ORIGINAL: steve00ram360
all 3?
yah all 3 what and who is mr murphy lol i must be living under a rock cuz im lost[&:]
Old Feb 28, 2006 | 12:08 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: ryans590
all 3?
Sorry. Fuel pump, regulator, and fuel filter. That is, unless, there isn't a separate filter inside of there.
Old Feb 28, 2006 | 02:21 PM
steve05ram360
all 3 are on the assembly... you change the pump and you get a new regulator and filter to go with it...
Old Feb 28, 2006 | 03:09 PM
Fubba's Avatar
Fubba
Steve,
I recently read an article that said pinging is normal under heavy conditions such as driving up a hill or pulling a trailer from a stop. It will not hurt the motor unless it is heavy pinging which is detonation causing the motor to fire earlier than when the piston is at the top of the cylinder. I mainly deal with GM motors specifically GEN 1 motors. The way I fix this is backing off of the timing a little. I know you're motor is fairly modified, so you may be able to reset the timing on your truck. Just an idea.
