My engine setup for 06
Old Feb 21, 2006 | 05:20 PM
RM_Indy's Avatar
RM_Indy
Default My engine setup for 06
Well things are getting closer now on my final setup for this year. Still waiting on a couple parts.
Hughes billet 55mm tb
M1/2bb (on 360 currently/will be modifying)
Hughes 1828 cam on the bench but decided Im not using it. Its way too small for the 408/hds.
Comp Cams, 236/242 @ 050, with 570/589 lift and cut on a 114 (just ordered)
Eagle billet 4340 stroker crank is rated for over 1000hp!! (should be here next week)
Eagle forged H rods
Wiseco custom forged, 8.5cr blower pistons (should arrive next week also)
Edelbrock 2.02 alum heads with 3 angle valve job, decked, gasket matched and stageIII porting now flow 290/248cfm @ 550 lift (24/36% over out of box #s/55%+ over stock hds)
Replacing Eddy springs with 650lift springs and titanium retainers/locks
MP gasket kit for all except under the heads
Cometics .042 mls head gaskets (not the.120 sc gasket/dont want to lower cr any more)
Arp head studs
Hughes main studs & main girdle/crank scrapper
Clevite bearings
8lbs of block fill
Mildon h/v oil pump
MP pinned oil pump driveshaft
MP double roller tchain
Modified oversized MP oil pan
Im having the rotating assembly balanced and blue printed. My machinist is rating it good to a max of 950hp @ flywheel.
Also have B&G 408 flashed pcm (borrowed) and a new MSD BTM for pulling timing under boost but dont want to use them.
Looking to get a FAST standalone management and probably 72lb injectors
The #s Im getting from software estimations is varying by almost 100rwhp so not sure where it will end up. Slowest its telling me is 11.6 ets, fastest, 10.92 and thats at 8-9psi only.
Any bets on what I will break first?
PS. in the picture below I did a mock up using my buddies 408 block not mine (mine will be black) and used his m1/4bb (I have 2bb version/still on 360) Everything else is mine. Wanted to make sure no issues with the studs and springs. Have to recheck with the 650springs in now that I think of it.
Old Feb 21, 2006 | 10:45 PM
Dodgeramman's Avatar
Dodgeramman
Default RE: My engine setup for 06
[sm=drooldude.gif] Dude what f*^k. I checked out Hughes, I never knew there was so much stuff out there for these things. I love those black tbs, would look mighty nice on mine. I gotta a dealer within 50 miles cool. Can't wait for some pics!!!!
Old Feb 21, 2006 | 11:14 PM
shott8283's Avatar
shott8283
scott wheres that dealer your talkin about?
indy that thing is gonna be sick...maybe ill jack it from ya next year so you can have fun with it this season..lol
Old Feb 21, 2006 | 11:21 PM
Dodgeramman
ORIGINAL: shott8283
Leckinger Performance in Onterio, just down the 90. thought it said somewhere else but this is still about 50 miles.
Old Feb 21, 2006 | 11:28 PM
shott8283's Avatar
shott8283
oh ok..i know where your talkin about
Old Feb 21, 2006 | 11:29 PM
shott8283's Avatar
shott8283
seems like everything around here is on the 90..or right off of it huh
Old Feb 21, 2006 | 11:38 PM
Tani1500's Avatar
Tani1500
[sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif][sm=drooldude.gif]
wana trade Please
Old Feb 22, 2006 | 08:36 AM
brute98's Avatar
brute98
I bet you will do 10s with that setup. If you're ever racing in the Valley area like Luskville or something let me know so I can see that power plant in action. [sm=gears.gif]
Old Feb 23, 2006 | 02:25 AM
RM_Indy's Avatar
RM_Indy
We have a Hughes dealer up here as well
I dont know about 10s but mid/hi 11s shouldnt be too difficult by the sounds of it. Cant wait to find out BTW, where is Luskville?
Old Feb 23, 2006 | 02:31 AM
muddy_blue_dodge's Avatar
muddy_blue_dodge
do you have any plans to run that on a dyno? or have you already? if so how much HP/torque are you makin
