Will Gen 3 rims on a Gen 2?
Old 04-18-2006, 02:01 AM
Bikenut's Avatar
Bikenut
Bikenut is offline
Default Will Gen 3 rims on a Gen 2?
I have a '99 2 WD 1500, front disc/rear drum brakes, with the factory 16" aluminum wheels. Will the factory 20" aluminum rims from a gen 3 (2005?) fit?
I'd greatly appretiate any info on this.
Old 04-18-2006, 03:10 AM
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
Default RE: Will Gen 3 rims on a Gen 2?
welcome to DF... they should fit no problem. I've seen several with the stock 20's from the gen3's on a gen 2 truck. check the bolt pattern to be sure.
Old 04-18-2006, 03:15 AM
The Burning Rom's Avatar
The Burning Rom
The Burning Rom is offline
Bolt pattern is fine. Should fit over the drum with no problems. Offset is fine as well.
Old 04-18-2006, 03:22 AM
shott8283's Avatar
shott8283
shott8283 is offline
[sm=icon_ladiesman.gif]
5X5.5 bolt pattern... its common for 2genners to pick up the 3genners wheels when they get knew ones... fit perrty and look good too!!!
Old 04-18-2006, 04:09 AM
Bikenut's Avatar
Bikenut
Bikenut is offline
Thanks for the promt replys.
Since I posted the question I've been doing some searching for info. From what I've found, and you've said, the bolt pattern is the same. I've also noticed that the gen 3s use a 9/16" stud while the gen 2s are 1/2", so I'm a little concerned about using the smaller 1/2" lug nut on the larger hole in the gen 3 rim. It would really suck to pull those nuts through the rims and lose a wheel. But, as long as you guys have seen this done before with good results, and it wasn't some guy scratching his butt on the side of the road wondering where his fourth wheel went, then I'll give it a shot. Now I just need DHL to figure out where they shipped two of the four wheels I ordered.
Thanks again.
Old 04-18-2006, 11:42 AM
JustinJohnson86's Avatar
JustinJohnson86
JustinJohnson86 is offline
Hmm, i never knew that the 3rd gens wheels fit on 2nd gens, thanks for the help guys! Now i need to linger over to the 3rd gen section and nab some 20's =D
Old 04-18-2006, 06:21 PM
crazy1snow's Avatar
crazy1snow
crazy1snow is offline
i found some locally, well about two hours away, but they wanted a grand for them with tires on... not too bad but gonna wait a bit on that. there are better looking 20's out there anyhow.
Old 04-20-2006, 12:05 AM
Spike7ss's Avatar
Spike7ss
Spike7ss is offline
I have a set of 20" alloys I am trying to sell around my place locally. No one up here wants the dam things. Well theres one guy but he wants them for an 05 Dakota. And believe it or not, they actually fit
Old 04-20-2006, 12:38 AM
Ram_Sport's Avatar
Ram_Sport
Ram_Sport is offline
sweet i should steal my dads wheels lol j/k
Old 04-25-2006, 12:39 AM
Bikenut's Avatar
Bikenut
Bikenut is offline
Ok, so I've got these 20's now. I roll one out to the the truck and attempt to put it on. Well, the bolt pattern is fine ... but ... when I pop on a front wheel the center cap pops out. The dust cover on the center of the hub sticks out too far! The original wheels bulge out in the center to cover the hub Do the gen3's have stubby hubs? Will a gen 3 hub/roto work on a gen 2 spindle?
I'd be willing to change the hub/rotos in order to get these wheels on, but not anything more than that. At that point I'd sell them. (hehehe, or buy a truck to fit the wheels!)
Any ideas?
Quick Reply: Will Gen 3 rims on a Gen 2?
