46re tranny ?
Old Jun 21, 2006 | 02:36 AM
The Burning Rom's Avatar
The Burning Rom
Default RE: 46re tranny ?
ORIGINAL: 556fmj
the 46re is for the 5.9 engine right? Don't your 3/4 ton boys with v-10's have a 47re? Will the 518 pan fit the 46re or the 47re... also, that tech article doesn't have a 46re listed for a 99... what gives[]
The 46RE/RH is the transmission that's found behind the 5.2/5.9. The 47RE/RH is found behind the CTD and V10. The 518 pan will fit the 46RE/RH. I'm also getting the impression (from looking at these other pans) that it will fit the 47RE/RH as well, which is a 618 transmision. Why they use so many different model designations is beyond me [&:]
As far as the band adjustment, the list is indeed incomplete. In the past we've come to the conclusion that the adjustments for 98 and 99 are the same as 97 and 2000.
Also, it's important to note that the band adjustments are in INCH pounds. There have been more than a few people that thought it was FOOT pounds....and their band adjustment ended with their truck on a flat bed. [:'(]
ORIGINAL: fiveliterbtr
Hmm, interesting...I never checked it out at that Mopartsracing.com site...the Mopar Performance pan at Summit (P5007740AB, same #) lists as not having a temp. sensor bung. May want to double-check before ordering it, may be only certain pans that have the extra hole
I know a few people that have installed them already. Theirs have all had the bung.
I see summit lists all of the Mopar pans as not having them, even though it says right in the description "and an extra hole for a temperature gauge." [8D]
Old Jun 21, 2006 | 06:46 AM
V10's Avatar
V10
ORIGINAL: The Burning Rom
The same pan fits all 727, 518, 618, 46RH, 46RE, 47RH, 47RE and 48RE transmissions. Want more model designations? The old 904 has modern day decendents just like the old 727- A998, A999, A500, 40RH, 40RE, 42RH, 42RE etc. etc.
Old Jun 21, 2006 | 09:35 AM
stnlycup's Avatar
stnlycup
ORIGINAL: shott8283
my new tranny tq converter and new cooler needed 15 qts to fill, and i just did a fluid change and it only took about 8 qts... dont know if that will help
i use the +4 synthetic and i realyl like it... added a wee bit of mpg,,, but every little bit counts
your pan rotted through? i coulda swore they were aluminum... mine is atleast
My pan is painted steel...The truck only has 42k on it,12k the last 4 yrs. The paint is bubbled up and one corner is dripping a couple drops a day. I figure getting a cast pans will solve the problem forever. Hope to have the truck till it falls apart. As much as i drive it ....should be a few yrs
Old Jun 21, 2006 | 06:54 PM
stnlycup's Avatar
stnlycup
Got a B&M from summit racing...$136.95 Pan,gasket,filter extention and bolts.... part #BMM-10280.....filter was about 16 bucks,Total was about $180 with shipping.
Old Jun 21, 2006 | 07:44 PM
dodgedlr's Avatar
dodgedlr
it should fit.
The 46RH 46RE 47RH 47RE 48RE are all the same trans. just RH/RE indicates if its a hydraulic or electronic governor. The 46/47/48 is a "size". Basically more clutch plates.
Old Jun 21, 2006 | 08:04 PM
GOD RAM IT's Avatar
GOD RAM IT
The mopar pan will not gain you hardley any fluid capacity. Trust me, Been there done that. I also had the B&M one and it wouldnt fit my 46RE tranny, because the solenoid hit on one of the internal cooling fins. It would fit the RH trannys. also when it says that there is 2 extra quart carrying capacity it is only for the 727, 518. It is normal capacity for RH and RE trannys. TRUST ME AGAIN.
THe only two that I know that give you extra capacity are the TCI pans and the Mag Hitec pans. The TCI offers a 2 quart capacity and maybe a 4 quart capacity. Mag Hitec only offers a 4 quart pan.
I have the TCI and its great. It has a drain plug and all. No sensor bung but I didnt care because if a sensor was put in the pan you would only be reading fluid that has already been from the cooler.
I find pictures
Old Jun 21, 2006 | 08:14 PM
GOD RAM IT's Avatar
GOD RAM IT
here is the stock pan and the B&M pan
here is the depth of the stock pan
Depth of the B&M
the solenoid that the internal cooling fins hit.
this is a picture of the internal fins and my beer of choice
Old Jun 21, 2006 | 08:17 PM
GOD RAM IT's Avatar
GOD RAM IT
here is the TCI pan compared to the B&M pan
the inside of the TCI pan
I turned my truck upside down to get a picture of it installed
GET the TCI pan they are worth it. My tranny ran 10 degrees cooler with it.
Old Jun 21, 2006 | 08:49 PM
stnlycup's Avatar
stnlycup
Summit says the B&M pan is 4qts larger....if not,i can just "modify" the internal cooling fin with a grinder
Also,Does anyone have the link for adjusting the tranny cable for a little firmer shift?
Old Jun 21, 2006 | 09:21 PM
GOD RAM IT's Avatar
GOD RAM IT
it is no where near 4qt extra.
It is 4 qt extra for the 518 and 727 trannys but not for the 46RE. I posted the pictures above. The Mopar pan is the same capacity as the B&M, but minus the cooling fins.
GET THE TCI PAN! Its 10 or 20 bucks more than the B&M and you get more holding capacity.
