46re tranny ?
Old Jun 22, 2006 | 12:11 PM
  #31
GOD RAM IT's Avatar
GOD RAM IT
Default RE: 46re tranny ?
I got the 128005
Old Jun 23, 2006 | 01:20 AM
  #32
stnlycup's Avatar
stnlycup
SUCCESS!!!....B&M pan came today,the inner cooling fin did hit the solenoid. I "engineered" it down with an angle grinder after checking with B&M tech dept. Went on without a hitch...drained about 5 quarts of fluid and put 7 back....prob could use another 1/2 qt...but it got dark,so I'll check it out tomorrow. Thanks to everyone who had advice,would have liked to have a deeper pan,but as much as i drive it.....It'll do
Old Jun 23, 2006 | 11:55 AM
  #33
GOD RAM IT's Avatar
GOD RAM IT
I was going to do the same thing but I figured that if I have to modify something that I paid for to fit my tranny than the company can have it back.
Im glad you got it worked out.
Old Jan 11, 2007 | 11:11 PM
  #34
87Indy500's Avatar
87Indy500
ORIGINAL: GOD RAM IT
I'm sort-of in the same situation at the moment. I got the B&M pan (and its a nice piece)cause they said it would work, but I don't know if I want to go modifying it. I guess for the price ($120) a littleediting isn't real bad though....
Is there any reason that I "should not" modify it, or will it work fine if I just remove a little of the inner cooling fin to allow for the servo??
Thanks
Old Jan 13, 2007 | 07:17 PM
  #35
stnlycup's Avatar
stnlycup
[/quote]
Thanks
[/quote]
I modified mine...after i called B&M and checked with them....have had no issues and am happy with the pan.
Old Jan 14, 2007 | 12:11 PM
  #36
87Indy500's Avatar
87Indy500
So what all did you do? I assume that one or two of the interior fins had to be gound down?
How far down and how many?
Old Jan 15, 2007 | 10:41 PM
  #37
stnlycup's Avatar
stnlycup
ORIGINAL: 87Indy500
I'll upload a pic....1 fin ........broke it with a hammer and then ground it down with a angle grinder
[IMG]local://upfiles/37700/060E6471C0CF4FCA8278F06F4D74F6CD.jpg[/IMG]
Old Jan 16, 2007 | 03:34 PM
  #38
87Indy500's Avatar
87Indy500
ORIGINAL: stnlycup
ORIGINAL: 87Indy500
Looks easy enough to me....Thanks!
Old Jan 16, 2007 | 04:08 PM
  #39
bamory's Avatar
bamory
ORIGINAL: stnlycup
What is TCI part # of the pan that you finally got? Guess its a good thing i dont need to drive my truck or I'ld be in trouble here
Still lookin for the link for tranny cable ajustment...anyone?......anyone?
Here ya go, this is what I used..........http://www.dodgeram.org/tech/transmi..._lever_adj.htm
Old Feb 2, 2007 | 12:08 AM
  #40
87Indy500's Avatar
87Indy500
[/quote]
[/quote]
Which filter extention did you need to use? The thick or the thin one?
Thanks
