3" body lift install
Old Oct 3, 2006 | 11:54 PM
bigjay's Avatar
bigjay
Default 3" body lift install
ive got 16" of suspension lift and now would like to go with a body lift as well, is it as straightforward to do as it looks like it would be, or are there some hangups ( im assuming there are... there always is, lol) anyone done this recently? thanks
jay
Old Oct 3, 2006 | 11:57 PM
Ram_Sport's Avatar
Ram_Sport
Default RE: 3" body lift install
[sm=ttiwwp.gif]
PICS NOW!! and uh, it should be straight forward..
Old Oct 4, 2006 | 12:00 AM
bigjay's Avatar
bigjay
im uploading pics as we speak, muah ha ha ha ha haaaaaa.
Old Oct 4, 2006 | 01:52 AM
Silver_Dodge's Avatar
Silver_Dodge
Your bumpers will be lower until you raise them up (since they attach to the frame). Gas tank filler neck might need some extension, and the steering might need an extension. If you get the body lift from Performance Accessories, it should come with all the hardware you need to make it all work though. Talk to Tani1500, he knows more about body lifts then I do, and has a 3" PA on his truck.
Old Oct 4, 2006 | 02:29 AM
Socha_62's Avatar
Socha_62
I got mine from Trail Master and it came with EVERYTHING I needed. Fuel filler extensions, front bumper brackets, steering extender, shifter extender, ect.
Its pretty easy, took me and a friend like 3 hours. Hardest part is the linkage extension and steering extention but if you follow the directions even those are easy. Also don't buy the rear bumper brackets, you can drill new holes 2" above the old ones and it will look fine GL and shoot us anymore questions if you have them.
Old Oct 4, 2006 | 05:33 AM
bigjay's Avatar
bigjay
thanks for the info guys, im going to do a rollpan on the back so screw the brackets, lol. trailmaster look slike the way to go, im a fan of complete kits, i hate piecing things together. thanks again
Jay
Old Oct 4, 2006 | 02:48 PM
Tani1500's Avatar
Tani1500
if i remember correctly trailmaster doesnt have a steering shaft extention but i could be wrong. i would go with PA, there the best know. my kit had everything i needed and half it i didnt even have to use. the direction where also straight foward and easy to follow.
Old Oct 4, 2006 | 03:37 PM
bigjay's Avatar
bigjay
funny, when i go to trailamasters site and fallow the links to body lifts it takes me to performance automotives site, maybe PA ands trailamaster have joined on these kits? the kit looks pretty good, i wonder if the supplied steering shaft will be sufficiant though considering the lift already on the truck?
Old Oct 4, 2006 | 06:04 PM
Socha_62's Avatar
Socha_62
ORIGINAL: Tani1500
I say your wrong, cause mine had one
Old Oct 4, 2006 | 08:34 PM
Tempsho's Avatar
Tempsho
x2 for Performance Accessories
the 3" BL kit was 100% complete for my 1999 Sport Ext Cab 4x4. Steering shaft spacer and everything (I didnt use it though, I bought the Borgeson shaft which is way better than stock, and you dont have to use the spacer) www.borgeson.com
The kit was around $240 (CDN) which is about $213 USD. Not bad of a price from www.nsor.com
I opted for the rear bumper brackets, and I havent had any issue with them. I dont plan on pulling a trailer or anything with the bumper anyways (It's now to high) so I dont see what the big fuss is all about.
