engines starts shaking when it gets hot...please help!!!
Old 10-23-2006, 02:27 AM
david28's Avatar
david28
david28 is offline
Default engines starts shaking when it gets hot...please help!!!
my dodge is a '95 1/2 ton with a 318 after the engine warms up it starts to shake, i replaced my sparkplugs, dist. cap, rotor, and wires.... what could be causing this??
Old 10-23-2006, 03:23 AM
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
Default RE: engines starts shaking when it gets hot...please help!!!
welcome to df...
check your o2 sensor, I had a o2 heater fuse blow which caused a similar problem. Another thing could be a vacuum leak at the throttle body.
Old 10-23-2006, 11:07 PM
david28's Avatar
david28
david28 is offline
where exactly is the o2 sensor on this truck...i am new to dodges..
Old 10-23-2006, 11:12 PM
timwag2001's Avatar
timwag2001
timwag2001 is offline
some trucks have o2 sensors in your exhaust before and after the cat. but some trucks only have one
Old 10-23-2006, 11:30 PM
david28's Avatar
david28
david28 is offline
thanks tim, is this heater fuse that steve mentioned in the same place?
Old 10-23-2006, 11:49 PM
timwag2001's Avatar
timwag2001
i think its all contained in the 02 sensor...
have you ever changed your 02?
Old 10-24-2006, 03:35 AM
david28's Avatar
david28
david28 is offline
nope i never have, what all is involved?
Old 10-24-2006, 12:31 PM
Socha_62's Avatar
Socha_62
Socha_62 is offline
All thats invloved is getting a wrench thats the right size and unscrewing it from the exhaust. Very simple basic maint. Crawl under the truck and you'll see some wires coing out of the exhaust, thats the O2. They can get pretty stuck in there sometimes. Don't be affraid to give it a really good tug, but don't break it off either. Most people come back and say they couldn't get it off. You really do have to give them a really good tug if they're rusted in.
Old 10-24-2006, 01:27 PM
asimpson97d's Avatar
asimpson97d
asimpson97d is offline
could be a torque converter problem too. buddy of mine had the same symptom and it turned out to be the converter.
Old 10-24-2006, 05:32 PM
nmason's Avatar
nmason
nmason is offline
what do you guys suggest for a replacement o2 sensor?
as for the original question, mine used to shake pretty good, but then i did a tune up. all has been well ever since.
Quick Reply: engines starts shaking when it gets hot...please help!!!
