no f***ing doubt!!!!!!
Old Oct 29, 2006 | 01:23 AM
20dodgeram01's Avatar
20dodgeram01
Default no f***ing doubt!!!!!!
well i went to change my front driver side axle seal out last night.. got the driver side hub and axle out.. got the differental cover out and oil drained.. got the passenger side axle out.. and went to take out the CAD to get the other part of the axle out.. (figuring in that at this point it has already taken 7+ hours to get this far).. and long and behold all 4 bolts holding the CAD on SNAP OFF!! so i went all that far for nothing.. i couldnt get that CAD out.. so i cant get the other part of the axle out.. so i cant get the carrier out to fix the driver side seal.. does anyone have any bit of info they can tell me about getting snapped off bolts out??? it took 7 hours just to get that far becuase for 1 we didnt have a big enough socket for the hub nut.. then when we did get it we ended up breaking a 1/2 inch breaker bar and socket wrench.. so i had to go back to my house to get a 3/4 inch breaker bar along with a 8 foot long 3 inch wide steel pole for enough leverage.. got the hub nut off and found out somebody put lock tite on it[:@] then it was another hour just beating the hub off.. but when those 4 bolts snapped i was pissed.. all that work for nothing.. well actually to look at the bright side it we did change the diff. fluid lol.. sorry im just venting out a very stressfull night.. started at 4pm and ended at 5:30am with a trip to the wafflehouse
Old Oct 29, 2006 | 01:49 AM
dillonjm's Avatar
dillonjm
Default RE: no f***ing doubt!!!!!!
You only have a couple options. A Craftsman easy-out MAY work. Otherwise you're looking at drilling out those bolts and re-tapping.
Old Oct 29, 2006 | 02:00 AM
Tani1500's Avatar
Tani1500
wait so you still didnt get the Cad out? if your jam a flat head in there you should be able to pry it right off since the bolt is only threaded in the axle itself. too of mine are broken off and i just slide it over them and put the other 2 bolts in. works fine. also if you get it out the it will be easier to get the bolts out.
Old Oct 29, 2006 | 12:22 PM
dillonjm's Avatar
dillonjm
Thought of another idea, might be able to weld a new head on the broken bolts if there is some still sticking out of the axle housing. The heat from the welding may also help break them loose.
Old Oct 29, 2006 | 01:01 PM
silverram99's Avatar
silverram99
I have welded nuts on to broken bolts before, get it tacked from inside the nut and then fill it in. Easier said than done, but it works.
Old Oct 29, 2006 | 07:17 PM
20dodgeram01
well the bolts are only about 1/4 inch to 3/8's.. something like that and they broke off right at the CAD so there is nothing sticking out.. they are in there good and i broke all 4 so i dont have any bolts to re-use.. so your saying i can just pry the CAD off the axle?? i think i might just have to drill out the holes and re-thread it.. thats gonna be a pain [:@]
Old Oct 29, 2006 | 08:34 PM
timwag2001's Avatar
timwag2001
autozone sells a kit for like $10. it comes with drill bits and drill bits that are like reverse corkscrews. you might be able to still get them out without too much trouble
Old Oct 29, 2006 | 08:51 PM
Ramdamit98's Avatar
Ramdamit98
I don't see why if all the bolts snapped, the CAD shouldn't come off with a little persuasion. Then like Tani said if your lucky and just snapped the heads off the bolts you may have a little of the bolt still sticking out of the housing once you get the CAD off.
Old Oct 29, 2006 | 11:13 PM
20dodgeram01
yeah true.. i might try that next weekend.. i've noticed today that it isnt the driver side leaking anymore.. its the passenger side?!?!? mustof screwed up the seal on that side putting it back in..
Old Oct 29, 2006 | 11:16 PM
Socha_62's Avatar
Socha_62
Park on a hill fora whole night to see if its leaking, then do the same for the next side. They could be both shot, mine ironitcally went at the same time.
