lift
Old Nov 8, 2006 | 07:11 PM
mossy765's Avatar
mossy765
Default lift
hey guys im thinkin bout puttin a lift on my 99 ram 2500 and its a 3" lift and im buyin it off my friend cause hes takin it off his cummins and puttin something different on it but he only wants 150 bucks for it and thats like super cheap for it so i think im gonna buy it off him and hes even gonna help me put it on so thats a great deal but the downfall is im gonna have to git bigger tires and i dont have the money so im thinkin bout gittin a set off ebay or somewhere like that so im askin u guys what are some cheap but better off road tires and i want 33's but i wanna keep stock rims so any info would b great. thanks
Old Nov 8, 2006 | 07:21 PM
mojo's Avatar
mojo
Default RE: lift
285/75 R16's are the equivelent of 33" tires. the problem with ebay is sometimes they are used ane once you change the tire beed it can be difficault to balance them. However all manufactures sell cheeper versions of their name brand, you can try Sam's Club,Wal Mart, Sears a local discount tire store and probable come up with a new set of rubber for cheap. If you ask for 33" tires though you'll pay through the nose so ask for the metric equivelent. You can also by the speedo gear from mopar for under ten bucks.
Old Nov 8, 2006 | 08:16 PM
mossy765's Avatar
mossy765
Default RE: lift
really? i thought 305s were equivalent to 33's
Old Nov 8, 2006 | 08:44 PM
muddy_blue_dodge's Avatar
muddy_blue_dodge
Default RE: lift
ORIGINAL: mossy765
285/75/16-- dunlop mud rovers. thats what i have. IIRC 120 apiece, i can check tho..... if you have 15 inch rims its like 105 tho.
Old Nov 8, 2006 | 08:52 PM
nhlbill's Avatar
nhlbill
Default RE: lift
A 2500 can fit 285/75/16's (33") without any lift. With a 3" lift on your 2500, I would not put anything less than a 35" tire on it or it's going to look too small. I think the 2500's have a 8" rim standard, so you could easily put a 315/75/16 on your stock 2500 rims and have ample clearance for 35's with your 2500 and a 3" lift.
As far as cheap.....Buckshot Mudders are cheap on E-bay. I think the last time I saw them they were under $600.00 for 4 Buckshot mudders in a 315/75/16.
ORIGINAL: mossy765
Old Nov 8, 2006 | 09:01 PM
muddy_blue_dodge
Default RE: lift
ORIGINAL: mojo
are you talkin about the gear that corrects your speedometer?? ok wow i guess thats a dumb question b/c im kinda restating what you said.... but i was just checking because i was told that those parts were not used in these trucks.....
Old Nov 8, 2006 | 09:02 PM
Ramdamit98's Avatar
Ramdamit98
Default RE: lift
ORIGINAL: mossy765
The first # in the metric measurement is the width. The second number is the aspect ratio (% of width = sidewall height). You need both those numbers plus the rim size to get the equivalent tire height in inches. 285/75 16 equals 32.8" or 33's 305/70 16 also equals 32.8. The metric way doesn't give you a direct tire height number. I know I have a tire calculator site saved to my favorites http://www.differentials.com/calc.html to make it easier to figure out. Who the hell wants to do the math.[:'(]
Old Nov 8, 2006 | 09:03 PM
Socha_62's Avatar
Socha_62
Default RE: lift
nhlbill is correct, on a 2500 you should be able to clear 35's no problem, anything smaller will look funny. And 285's are roughly 33 and 305s are roughly 35s
Old Nov 8, 2006 | 09:09 PM
mossy765's Avatar
mossy765
Default RE: lift
ok next ? how much aprrox. do u think 35's will hurt my gas mileage
Old Nov 8, 2006 | 09:16 PM
Ramdamit98's Avatar
Ramdamit98
Default RE: lift
Larger tires will hurt your gas mileage. More weight, more inertia to overcome more gas.
