ABS and Brake light
Old Nov 9, 2006 | 05:03 AM
IndyRamMan's Avatar
IndyRamMan
Default ABS and Brake light
My ABS and Brake lights are consistantly on. i dont have an abs diognostics reader, so i dont know what it is. what do you think it could be?
Old Nov 9, 2006 | 05:57 AM
FingerBang's Avatar
FingerBang
Default RE: ABS and Brake light
had the same problem, a new vss/rwss/abss whichever they want to call it, took care ofthe problem. Its inthe rear differential and should be about $40.
Old Nov 9, 2006 | 06:03 AM
dodgerules86's Avatar
dodgerules86
Yea, seems to be a common problem.
Remember what FingerBang said, the sensor on the rear differential, not the one on the transmission (sometimes people get confused about this).
Old Nov 9, 2006 | 06:07 AM
FingerBang's Avatar
FingerBang
ORIGINAL: dodgerules86
Remember what FingerBand said, the sensor on the rear differential, not the one on the transmission (sometimes people get confused about this).
FingerBAND???
i wouldnt PAY to see them....
Old Nov 9, 2006 | 06:13 AM
dodgerules86
ORIGINAL: FingerBang
FingerBAND???
I fixed it, I fixed it. Sorry, I can't be write all the tyme.
Old Nov 9, 2006 | 06:17 AM
FingerBang's Avatar
FingerBang
oll, te moo
Old Nov 9, 2006 | 09:09 PM
1RewdRam's Avatar
1RewdRam
hey, just curious if this would apply to my '01 S10 Blazer. I have the same problem, but intermittent. Was told the "brake computer" (apparently it has it's own) and is quite expensive. What are you all talking about as far as a part?
Old Nov 9, 2006 | 10:57 PM
xyzik's Avatar
xyzik
if it so happens that you have cruise control issues, check your brake light switch.
Old Nov 10, 2006 | 04:35 AM
Racinfan83's Avatar
Racinfan83
The Vehicle Speed Sensor that is attached to the rearend. There is also one on the tranny, but the rearend one is the one that causes the abs and brake light to come on when it goes bad......
Old Nov 10, 2006 | 04:49 AM
ryans590's Avatar
ryans590
ORIGINAL: IndyRamMan
...i dont have an abs diognostics reader...
depending on the year you can get the codes by turning the key on-off-on-off-on they will ither be the c/e light flashing (97 and older) or a number on the odometer (99.5 and newer) if your like me and have a 98 your outa luck...they musta figured everyone in this year was rich and could buy the code readers lol
