Superchips or hypertech?
Old Jan 13, 2007 | 12:40 AM
  #21
974x4's Avatar
974x4
Default RE: Superchips or hypertech?
so if you had the money, youd by a programmer over a mopar performance pcm? jus wanted to get some ideas...
Old Jan 13, 2007 | 02:31 AM
  #22
ripto's Avatar
ripto
ORIGINAL: Ramdamit98
It shouldn't be hurting anything. A buddy of mine has one and he says his truck runs a little smoother with it. He doesn't notice any performance gains but he thinks it runs a little better.
As for the cables the chip is just in-line where the cable goes. You unplug the cables from the chip, unplug the chip from the PCM and then plug the cables backinto the PCM in the spot where the chip was.
I would disconnect the battery while doing it and reset the PCM while the battery is disconnected.
EDIT: It not recommended to use the jet chip and a programmer at the same time, so you'll want totake the jet chip out before using your hypertech again.
Hmm so I wonder if I look at that and see it is infact what you are describing if I take that out if I will still hear some pinging, I'm sure I will but maybe there won't be as much with the hypertech too.
Old Jan 13, 2007 | 12:29 PM
  #23
2 Marks's Avatar
2 Marks
I have about 1,000 miles on my Hypertech now... spent $300, set for 87 octane, adjusted tires for my 285's. Pickedup significant power especially towing. Picked up several miles to the gallon... 1,000 miles in appears to be 4MPG. Very pleased; no pinging with everything stock but a K&N filter. $300 bucks well spent.
Old Jan 13, 2007 | 06:12 PM
  #24
badram1500's Avatar
badram1500
I've got the Superchips in mine and I like it so far. Hasn't helped on milage but the power increase is always welcome. I guess you don't be a truck for milage anyway. I run mine on the towing setting and haven't had any pinging troubles
Old Jan 13, 2007 | 09:02 PM
  #25
rydog2624's Avatar
rydog2624
where can i get the superchip the cheapest at besides ebay?
Old Jan 21, 2007 | 06:46 PM
  #26
DALEMOPAR's Avatar
DALEMOPAR
ON MY 97 THE ONLY WAY TO ADJUST SHIFT POINTS IS WITH THE CABLE ON THE THROTTLE BODY. IT ACTS AS THROTTLE PRESSURE.
Old Jan 21, 2007 | 09:41 PM
  #27
hicktown's Avatar
hicktown
Would you guys recommend either of those programmers for the 3.9 liter?
