1998 ram 2500 5-speed gearing????
Old Jan 12, 2007 | 05:06 AM
THEGOLDPRO's Avatar
THEGOLDPRO
Default 1998 ram 2500 5-speed gearing????
hey guys my question is i have a 1998 2500 5.9 litre with a 5-speed trans, i was wondering what rear end gearing i most likely had, and what i would be able to change it to, im looking to lower the gearing just a bit for alittle added towing power, thanks in advance
Ben
Old Jan 12, 2007 | 06:45 AM
akyne's Avatar
akyne
Default RE: 1998 ram 2500 5-speed gearing????
My truck has a sticker in the glovebox with the axle ratio. There should also be a tag somewhere on the axle cover itself with the ratio. If i'm not mistaken, 2500s with a V8 came with a Dana 60 rear axle for which the factory gear ratio was either 3.54:1 or 4.10:1. Your options for new gear ratios are basically limitless with the Dana axles. If you find you're running 3.54's, a switch to 4.10's with stock tires makes for pretty good low end. Any lower and you'll be hurting your highway performance.
Old Jan 12, 2007 | 04:30 PM
zique's Avatar
zique
open your hood and look up. there should be a tag up there that tells you your gearing. Or, either of the options akyne gave you are good as well.
Old Jan 12, 2007 | 04:40 PM
ASH's Avatar
ASH
On a 1998, the sticker should be under the hood. I think they switched to putting them in the glove compartment in 2000 or 2001.
Old Jan 12, 2007 | 05:09 PM
THEGOLDPRO's Avatar
THEGOLDPRO
awesome guys thanks a bunch ill go take a look now.
Old Jan 12, 2007 | 05:15 PM
THEGOLDPRO's Avatar
THEGOLDPRO
ok guys i took a look i do have a dana, and the ratio is a 3.55, so i assume the 4.10's are the next best option, where do i go about buying them???? i appreciate all the help guys thanks alot.
Old Jan 12, 2007 | 11:58 PM
THEGOLDPRO's Avatar
THEGOLDPRO
anybody, lol
Old Jan 13, 2007 | 12:44 AM
TMS Bill's Avatar
TMS Bill
Ring and pinions for the D60 should be as common as bikinis at spring break. Do an internet search and you'll probably get a couple of thousand hits.
Old Jan 13, 2007 | 12:51 AM
mopar98's Avatar
mopar98
Finding them is easy on the internet .
Installing them can be tricky though if u don't have the proper tools or ifdon't feel comfortable shop around for a good shop price.
Old Jan 13, 2007 | 12:57 AM
TMS Bill's Avatar
TMS Bill
IIRC there is an EXCELLENT illustrated write-up on how to rebuild a D60 on either Pavement Sucks or Pirate 4x4.
