tire size
Old Mar 6, 2007 | 05:03 PM
Jvog's Avatar
Jvog
Default tire size
I am looking to buy 33" tires for my truck. I currently have 285/75/R16s on there now and I wasn't sure how wide the 33" tires should be since most of them use the metric measurements and say the rim size is 16.5.
Old Mar 6, 2007 | 05:30 PM
BradBeyer's Avatar
BradBeyer
Default RE: tire size
This site has a conversion calculator
http://www.dakota-truck.net/TIRECALC/tirecalc.html
Old Mar 6, 2007 | 05:37 PM
junkman306's Avatar
junkman306
You already have 33's. The 285's are 32.86 inches in diameter.
Old Mar 6, 2007 | 08:59 PM
TMS Bill's Avatar
TMS Bill
Care to attempt 305/75/16? You only need a LITTLE lift.
Old Mar 6, 2007 | 11:24 PM
Jvog's Avatar
Jvog
I don't want a lift I'm just going to level it out. I already saw that calculator and it says i need 33x11.22x16 tires....if you can find a tire that sizes its width is 11.22 than go for it....I've been seeing ones that are 12.5, would they be too big for the rim?
Old Mar 7, 2007 | 12:40 AM
TMS Bill's Avatar
TMS Bill
A level IS a 2" lift ... front only. I'm running LT285/75/16 (33's) without a leveling kit. With one ... I could go quite a bit bigger.
Old Mar 7, 2007 | 01:10 AM
Jvog's Avatar
Jvog
yea ur right it is technically a lift...with my 2 inch leveling kit what is the biggest tire i can fit on my 16 inch stock rim without rubbing?
Old Mar 7, 2007 | 01:23 AM
TMS Bill's Avatar
TMS Bill
Each truck is a bit different ... to find out about yours in particular ... I'd go up a size or two each time I needed new tires. That's what I did. If I ever level mine (or put a cheap 3" lift on it) I'm swapping on 305's when my 285's are history. I started with 265's. 245's are stock.
Old Mar 7, 2007 | 01:53 AM
Jvog's Avatar
Jvog
well i already have 285/75/16s on there but theyre worn out. Thats without the leveling kit so im curious as to whether or not i can fit 35" tires on it with the leveling it...ive searched the forums and got a bunch of different info so im trying to get a final answer.
Old Mar 7, 2007 | 01:58 AM
TMS Bill's Avatar
TMS Bill
Where are you planning to get the tires?
