End-all Be-all plenum thread
Old Jul 7, 2013 | 02:56 PM
  #781
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by Nick Bain
SOOOOO I did not read the whole thread but is there not a vacuum kind of test that can be done to check the plenum, like wouldn't crankcase show above average vacuum due to extra air being pulled in through the gap? I am not an expert on how the system works just throwing out an Idea that some one can back up or shoot down with sound mechanical reasoning.
Yes, there is a vac test. But it's a waste of time(As stated many times in this thread) and will only show if the leak is severe. I know it's long, but if you read the thread, you wouldn't have to ask this question and make the thread even longer.
Old Jul 8, 2013 | 06:07 PM
  #782
Nick Bain's Avatar
Nick Bain
checked my plenum today just by looking down through the TB with a flashlight, I did not see any oil pooling and I could see clean steel.
Old Jul 8, 2013 | 06:09 PM
  #783
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
you have to remove the TB and it's better to use an inspection mirror when checking so that you can see in the corners of the keg.
Old Jul 9, 2013 | 12:29 PM
  #784
zman17's Avatar
zman17
Originally Posted by candymancan
I mean probly not.. The original bolts didn't have thread locker and they were fine from what I could tell anyway..
Just makes ya wonder you know ? 84 inch lbs is not alot
The original bolts didn't need thread locker, since they were too long and bottoming out in the hole.
Old Jul 31, 2013 | 03:20 PM
  #785
candymancan's Avatar
candymancan
Zman, Im not talking about the intake bolts.. I ment the pan bolts.. you know those short black bolts on the pan.. lol
Old Jul 31, 2013 | 04:00 PM
  #786
dodge dude94
Yes, those were the bolts he was speaking of.
That's actually part of the reason for the blown plenums, the plenum bolts were too long.
Old Aug 1, 2013 | 11:22 PM
  #787
candymancan
I cant remember how long they were.. All I know is I used the ones that came with my pan... they were really short stubby ones.. I don't remember the original bolts being long either.. ? They couldn't have been more then half an inch long... How is that too long ? They are short like valve cover bolts. and those rattle lose that's what im worried about.. man I wish I thought about thread locker lol
Old Aug 1, 2013 | 11:24 PM
  #788
dodge dude94
The bolts are short, but there is a little "tit" on the end of them that makes the bolt bottom out in the hole.
Old Aug 5, 2013 | 08:21 AM
  #789
jokerdp's Avatar
jokerdp
I have a 96 1500 4x4, 5.2l. There is a missfire about 50 mph. I changed out the plemeun gasket, plugs, wires, rotor, cap, thermostat, flushed coolant, and oil change. I runs good until it warms up then it starts to misfire again. The misfire is not as bad as before but still there. I am thinking it is prob the cat or pre cat o2 sensor. Does anybody have any thoughts on where I should go next. I really don't want to replace the cat if I don't have to. Would any other sensor cause this. How can I test or verify what is wrong. Thanks.
Old Aug 5, 2013 | 08:52 AM
  #790
If you are over 100K miles, replace the pre-cat O2 sensor, and see if that doesn't help.
