grindin noise. now no gears in tranny
Old Sep 21, 2011 | 07:31 AM
DoubleL24's Avatar
DoubleL24
Default grindin noise. now no gears in tranny
I have a 99 ram 4x4 wit auto tranny and thiis morning going to work started hearing a grinding noise and when I get to work try to back up and I get nothing, try to put in drive get nothing. Guess my tranny is f**kd. Anyone have similiar experience.
Old Sep 21, 2011 | 07:36 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Could be the transfer case.
Old Sep 21, 2011 | 07:47 AM
DoubleL24's Avatar
DoubleL24
Is there a way to find out?
Old Sep 21, 2011 | 07:54 AM
zman17's Avatar
zman17
Same thing happened to my 98. I removed it, and put the truck in drive and looked to see if the tranny shaft spun and plus there was no grinding.
Old Sep 21, 2011 | 08:05 AM
DoubleL24's Avatar
DoubleL24
I might have to try that. When it started grinding seemed like a lot of vibration towards front of truck. Would that sound like the t case
Old Sep 21, 2011 | 08:36 AM
DoubleL24's Avatar
DoubleL24
If it is the t case what's the difference in an NP231 and a NP241DLD. Or what would be a good t case to put in it?
Old Sep 21, 2011 | 10:33 AM
see if you can find a 231DHD, direct bolt in, and a little meaner than the run of the mill 231D.
Old Sep 21, 2011 | 01:06 PM
DoubleL24's Avatar
DoubleL24
I went out and tried it and still won't go forward or back and it was hard shifting from reverse to forwards and than back to park. What you guys think?
Old Sep 21, 2011 | 01:17 PM
merc225hp's Avatar
merc225hp
Just a couple of Q's, have you done a visual inspection under the truck, tranny, t case, shift linkage, look for cracks, big holes, leaking fluid. Does the t case shifter still move? if so have you tried moving the truck in 4 hi or 4 low?
Old Sep 21, 2011 | 01:37 PM
DoubleL24's Avatar
DoubleL24
Everythin is hookd up no leaks. I jus tried again and put it in 4 low and it wouldn't go so I gassed on it a bit and it poppd and truck jumped and now it moves, put back in 2wd and will go forward and back. I'm so confused.
