grindin noise. now no gears in tranny
Old Sep 22, 2011 | 07:27 PM
  #21
Pull the fill plug on the t-case, once you have it out, pull the drain plug, capture the fluid, and see if there is anything you'd rather not see in it.
Old Sep 22, 2011 | 07:54 PM
  #22
DoubleL24's Avatar
DoubleL24
ok will do. Im gonna do a tranny service change fluid and filter any special fluid i should use? also is it same kind of fluid for the t-case or do you fill that up seperately?
Old Sep 22, 2011 | 08:11 PM
  #23
zman17's Avatar
zman17
Retired Moderator - RIP
I'm thinking maybe you have a vacuum problem. And what you are hearing is the front axle. http://www.dodgeram.org/tech/repair/..._engagment.htm
Old Sep 22, 2011 | 08:40 PM
  #24
chadhager03's Avatar
chadhager03
Ya that happened to me but it was a consistent grinding noise, if you look at the vacuum lines by the front of the skid plate (mine where red and black) they go to a metal tube (near the y pipe) where the exhaust burnt a hole in it. I replaced it and the noise went away.
Old Sep 22, 2011 | 09:18 PM
  #25
chadhager03
*if that's your problem, i didn't read the whole post.
Old Sep 22, 2011 | 09:53 PM
  #26
DoubleL24's Avatar
DoubleL24
would that cause the tranny to not go into gear?
Old Sep 22, 2011 | 09:56 PM
  #27
DoubleL24's Avatar
DoubleL24
would the vacuum maybe cause the t-case to maybe shift into neutral? where i wasnt getting reverse or forward gears? Kinda makes sense. Just wierd that it stopped and now works fine now.
Old Sep 22, 2011 | 10:20 PM
  #28
No, vacuum won't do squat to the T-case. Shifter on the t-case just pushes around a vacuum switch. That's it.
  #29
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Have you tried shifting the t-case into the different gears???
Old Sep 22, 2011 | 10:56 PM
  #30
candymancan's Avatar
candymancan
Just throwing this outa the blue, but maybe the tcase chain is heavily stretched and its skipping teeth ? I know on my Jeep when you go from 4Fulltime to 4low it will grind REALLY bad if you dont YANK! the lever back really fast and instead pull it really slow.. (Your suppose to yank it fast fyi)
