cummins swap?
Old Nov 4, 2012 | 11:02 PM
haus84's Avatar
haus84
Default cummins swap?
i have a 98 2500 with the 360 and am wanting to drop in a 24v. it already has the nv4500 tranny and i think the rear end would hold it well enough, has anybody had experience doing these swaps? any tips before i start getting into it. would i be better off getting a motor out of a wrecked outfit or just getting a long block straight from dodge? i planned on putting a south bend clutch in it while i have it apart any other major components i should swap out?
Old Nov 4, 2012 | 11:29 PM
QuadCabLuv's Avatar
QuadCabLuv
Incase u were wondering why noone has responded, it is because we are tired of answering the same questions over and over and over and over. You get the point. There is 1 thread a day about this. Try searching and you should find some info.
Old Nov 5, 2012 | 12:06 AM
Please read: https://dodgeforum.com/forum/2nd-gen...new-topic.html
The, by the powers invested in the search function: https://dodgeforum.com/forum/2nd-gen...mins-swap.html
Old Nov 5, 2012 | 09:36 PM
haus84's Avatar
haus84
yeah i already read all 17 pages of it, problem is i would like to drop in a 6BT not a 4BT, other part is the guy that did that one seams to have a pretty decent understanding of dodge diesels... i do not. what i did learn from that was i am going to have to change out my fuel pump and alter my fuel lines a bit, change my drive shaft length, and do some major screwing around with parts of the wiring harness and that i should be able to use my existing motor mount locations just with the cummins mounts. what it didn't tell me was if i will be able to use my existing dash, or what parts of the wire harness i will have to alter. thankfully it did have suggestions on what guages to add on the A pillar. all i have dealt with before for motor swaps have been carb gassers, no computer, no wiring harness, and nothing like a diesel. i know enough to guess that a 5.9 cummins wont run on the computer that a 5.9 gasser does. i also figured from one of the posts in there that when i do the swap i will have to have the 5th gear nut welded in my tranny or it will probably fly off.
now back to what i was origionally asking about before everyone assumed i was a complete idiot and assumed i didn't already try searching it
Old Nov 5, 2012 | 11:19 PM
Moochoff's Avatar
Moochoff
Why do you want to do the 24v? the early '98s were 12v and much simpler, more reliable, and more capable of big power...
A computer would still be nice, but not absolutely required.
Any questions about the differences I might be able to help a little more
EDIT: to help with the questions already listed... Rear end will probably be fine. Know which dana you have? And the nv4500 will need a torque converter.. could do the 5th gear nut fix while youre at it as well
Old Nov 5, 2012 | 11:40 PM
UnregisteredUser's Avatar
UnregisteredUser
That would be a very cool trick!
Old Nov 6, 2012 | 12:07 AM
Moochoff's Avatar
Moochoff
Hahahaha my bad, Im switching through 4 different forums and mixed her up!
4500 shouldnt be that hard to swap over, probably just a bellhousing/clutch difference
EDIT: My title on cumminsforum is actually "drunk poster"... I often need double checked lol
Old Nov 7, 2012 | 12:45 AM
haus84's Avatar
haus84
i am not trying to push big power, 2wd and this truck has one purpose pulling a horse trailer, the gutless 360 in it does ok with the 18ft stock trailer i have now, however SHE is getting ready to buy a 4 horse slant load with tack and living quarters. was looking at a 24v becausei can get one used for about $2500 but not having the same luck finding a 12v for similar price so just trying to save some $$$ also didn't know the early 98s had the 12 but definatly willing to opt for the 12 if it will save me alot of headache. had i known this was coming up i would have just bought a new truck instead of the car i just got
will my existing dash work?
Old Nov 7, 2012 | 01:13 AM
crazzywolfie's Avatar
crazzywolfie
i think it would be so much easier for you to just sell your truck and buy one with a Cummins already in it.
Old Nov 7, 2012 | 08:04 AM
Moochoff's Avatar
Moochoff
^It would probably be easier, and you might only save a small amount by swapping...
I am using my dash by just swapping over my sensors. And for the record there will probably be a headache, but just less of one with a 12v. The injection pump(p7100) from 94-98 was also a lot more reliable than the 98.5-02 VP44
Go to 4btswaps.com and check out some of their stickies... The site says 4bt, but there are a TON of 12v swaps there along with other motors like isuzu diesels and some others I hadn't heard of before
