3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
level/ lift kit or both?
Old Feb 26, 2015 | 06:47 PM
808nihon's Avatar
808nihon
Default level/ lift kit or both?
Any recommendations on a level or lift kit or possibly both from the stock height?
Old Mar 4, 2015 | 12:31 PM
The only "lift kit" made for these trucks is a body lift. Suspension your stuck with front leveling spacers and rear helper springs or blocks. You can get maybe 5" total lift with that, and if your 4x4, you will be stressing the heck out of the already weak front end parts.
https://dodgeforum.com/forum/3rd-gen...ze-thread.html
Old Mar 5, 2015 | 07:37 AM
808nihon's Avatar
808nihon
front leveling kit then. Thanks for input
Old Mar 5, 2015 | 07:39 AM
Vehicle info?
Sorry, forgot about this. There IS a lift kit for the Dakota, if you can afford it.
http://jackmyride.com/
Old Mar 6, 2015 | 12:25 AM
808nihon's Avatar
808nihon
how weak are the front ends? was just thinking on leveling the front but do I have to do anything to the rear? Lift bocks, leaf springs?
Old Mar 6, 2015 | 12:28 AM
808nihon's Avatar
808nihon
Is Performance Accessories any good? They have a body lift and level kit total is 5" lift!!
Old Mar 6, 2015 | 08:04 AM
Are you 2 or 4wd? Do not go above 2" leveling kit on the front if 4x4. It will stress the heck out of the ball joints, tie rods and CV axles. Front ends are known weak points on these trucks.
Old Mar 6, 2015 | 09:39 AM
dakotaff's Avatar
dakotaff
Performance Accessories has the 3" body lift of choice for our Dakotas. I assume their 2" leveling kit would be good too. You can find the PA body lift for about $360 (ish), and a 2" leveling kit (Daystar is a favorite around here) for about $110.
If your Dakota is a manual, you'll need another piece.
Old Aug 6, 2015 | 09:56 AM
!Jstevens!'s Avatar
!Jstevens!
What "Other Piece" is needed if your truck is a stick shift?
Old Aug 6, 2015 | 02:25 PM
dakotaff's Avatar
dakotaff
