Question about TB and TBS
RE: Question about TB and TBS
Get your money back on that throttle body spacer, otherwise it makes a great paper weight. That's all it's good for. Most if not all of us here on DF swear by the Fastman, Dan Arcand for modified throttle bodies.Go to www.thefastman.com He does outstanding work and the price is unbeatable. You will not be disappointed.
Our TBs are concave inside so even if you get a fastman TB of the same diameter of 68 its a true 68 so its the same diameter all the way through... thus alowing for more air(brought in by your CAI) to mix with more fuel... alowing for more HP and TQ... :-D
Heres a good thread that might help explain it better... and at the Very least you can see a Stock TB side by side with a true 68mm Fastman TB
Trending Topics
we have a session on sept 9 for dyno runs. i have yet to do a run with the new tb. but by the seat of the pants it tells me at wot. it is better then the stock. here is a pic. they are the same size as a unit. it is the internal size that is different. our stock tb are coned shape like a coke bottle fat at one end and skinny at the other. the fastman removes the cone shape and turns it into a coke can that is the same size top to bottom. easy install and for 180.00 cant beat the price
[IMG]local://upfiles/31284/87909A834933475F8F41A845A3446B2E.jpg[/IMG]
ORIGINAL: curtiplas
Superdak... I was looking at Fastman's site again.. and it says that is 180 for the TB and then another 100 for the core... wtf is the core??
