can i tow my jeep with my dakota ????
Old 08-06-2007, 07:18 PM
akashooter's Avatar
akashooter
akashooter is offline
Default can i tow my jeep with my dakota ????
hey i have an 06 4x4dakota with the 3.7 would i be able to tow a cj5 that weighs 3500 lbs?
thanks
Old 08-06-2007, 07:24 PM
Altair's Avatar
Altair
Altair is offline
Dak attack!
Default RE: can i tow my jeep with my dakota ????
ORIGINAL: akashooter
thanks
Well, you need to figure out what the max towing capacity on your truck is, then add the jeep and weight of the trailer together... that's if you want to do it safely.
Old 08-06-2007, 08:43 PM
turbot_bird's Avatar
turbot_bird
turbot_bird is offline
my 4.7 will pull my 79 k-10 easy but I dodnt know about the 3.7
Old 08-06-2007, 08:48 PM
mb18's Avatar
mb18
mb18 is offline
I would say, yeah, probably. Especially if you're going a fairly short distance.
Old 08-06-2007, 09:22 PM
texasbluedak's Avatar
texasbluedak
texasbluedak is offline
I was curious as to how much we can pull with the 3.7 also. I have it and alot of these guys say to look in the glove box to see what kind of gear ratio you have, but I still don't about mine since my glove box is pure black and nothing in it, didn't even get an owners manual!! According to Dodge at their website its a straight 3250 pounds, although further down it says a max of 7700 pounds (if properly equiped). I think with the jeep and trailer, you'll be too heavy for a safe tow. If you do it, at least make sure to back the jeep up on the trailer.
Old 08-06-2007, 09:26 PM
Altair's Avatar
Altair
Altair is offline
Dak attack!
Some years have the sticker in the glovebox and some don't, at least that's how it seems. I have an 05 and no sticker in the glovebox on mine. If you call your dealer and give them your VIN# they can tell you. Or if you go in with it you can have them print you off a sheet listing all the options on your vehicle.
Old 08-06-2007, 09:36 PM
mb18's Avatar
mb18
mb18 is offline
The rating varies from 3250 to 7100, I think, depending on how you're equipped. Having the tow package ups your rating. Having the V-8 ups the rating. Having the auto transmission ups the rating. Having the 3.92 gears ups the rating. If you have a V-6, with the auto and 3.92s you'll probably be OK over a short distance with that weight. If you have the 3.55s, I might hesitate, but, again, depending on the distance and terrain, I might give it a try.
Old 08-06-2007, 09:49 PM
texasbluedak
I'm going by the dealer in the next couple of days and I'll have them print me out the sheet. Trying to finally sort out the rear shimmy when breaking at highway speed. Thanks for the info!
Old 08-06-2007, 11:36 PM
herkguy's Avatar
herkguy
herkguy is offline
http://www.trailerlife.com/output.cfm?id=1073737
Here is the link to the trialer life towing guide for 2006. You need cab/drivetrain/eng/trans/gear ratio.
06 cc 4wd 3.7 man trans w/3.55 gears = 3900lbs towing
auto trans w/3.55 gears = 4400
auto trans w/3.92 gears = 4700
for quad cabs subtract 100lbs off of each rating
your axle ratio is also on a tape wrapped around the rear axle and is coded on the door tag
I hope this helps.
Quick Reply: can i tow my jeep with my dakota ????
