Rough country lift!!!!!!!!
Old Oct 14, 2007 | 08:51 AM
  #41
Dak_in_Black's Avatar
Dak_in_Black
Default RE: Rough country lift!!!!!!!!
ORIGINAL: studlyblueiz
Yep, no sense in add-a-leafs. They just add-a-stiffness. Seriously though they make your ride quality go down compared to OEM spring stiffness. Most dislike 3" blocks for such small gain that's why lift companies use combo's like a 2" block lift and 1" add-a-leaf. That was just an example not actual lift. I agree with MW4000 with a block you're atleast guaranteed 3" in the rear. Springs can be approximate and can be affected by weight or model differences like quad cab, single cab, etc.
Besides Dak in Black my jeep sits way taller than any lift these lift companies will ever manufacture for most vehicles and my wife gets in just fine. And it offers healthy jumping excercises and ensures proper stretching before your workout.
I think I undertand what you are talking about, but doesn't ading spacers (or blocks) compress the OEM suspension limiting travel and possibly make the ride harsher? I am stilllearning all this stuff....
Old Oct 15, 2007 | 12:09 AM
  #42
studlyblueiz's Avatar
studlyblueiz
Shouldn't, your just relocating your spring 3" higher on top of the axle. Worst thing blocks do is increase possibility of axle wrap or wheel hop. You put a greater moment arm on springs when you use blocks and this can cause your spring to kinda make a lazy S shape when a load or torque is applied. If you've ever engange the parking brake on an old bronco (or any vehicle with leafs on top of the axle) and rocked it back n forth you may see the rear axle pinion rotate up & down. This is easier to do when you use blocks. I think offset springs help eliminate axle wrap. But traction bars are most effective.
But not to stray away from thread topic I still vote go for it make the lift. Keep it on an easy budget b/c low demand on high lifts just make it expensive. Like 2gen Dakota lifts were way to expensive compared to a Ram lift of greater size.
Old Oct 16, 2007 | 01:48 PM
  #43
RCXRAIDER's Avatar
RCXRAIDER
for anyone wanting to know about the durabilty of our products, this is another one of the guys up here's D.D.,
this should calm anyone worried about our kit being a mall crawler.
http://www.youtube.com/watch?v=I64jQV9t968
Old Oct 16, 2007 | 08:11 PM
  #44
pro4x4's Avatar
pro4x4
I'm not worried about rough country's kits I know they will be good. Just hurry the heck up and get a kit made for our dakotas.
Old Oct 17, 2007 | 07:56 AM
  #45
vandutton's Avatar
vandutton
So I'm probably jumping the gun here, but any idea when this kit will be available?
Old Oct 17, 2007 | 12:39 PM
  #46
Handy05's Avatar
Handy05
I would just like to fit 33s
Old Oct 17, 2007 | 11:35 PM
  #47
06TRX's Avatar
06TRX
sign me up i want 35' tires
Old Oct 18, 2007 | 12:13 AM
  #48
vandutton's Avatar
vandutton
I can fit 33" with the body lift and TM level. I'm hoping to get 35"s with this kit and maybe bigger blocks.
Old Oct 18, 2007 | 02:03 AM
  #49
fbnzippy's Avatar
fbnzippy
AN acctuall Suspension lift instead of the presently avail Body lift. HECK YA I'd be all over that like a fat kid on a smartie. 3/3 5/3 3/1 whatever. I really need more elevation in general.
Old Oct 18, 2007 | 07:40 PM
  #50
Cuban11182's Avatar
Cuban11182
So any rough idea on when the lift could be out???
