Engine noise on startup
Old Nov 7, 2007 | 08:40 PM
  #41
nowick's Avatar
nowick
Default RE: Engine noise on startup
goes on and off all damn day
Old Nov 7, 2007 | 08:52 PM
  #42
herkguy's Avatar
herkguy
Have those brains at Dodge checked out the seat weight sensor system in the passenger seat, sounds like thats what could be bad. Maybe its stuck or improperly set. Maybe they broke a connector under the seat when they were installing the NAVI system, if they moved the eseat back out of the way. Just some thoughts.
Old Nov 8, 2007 | 06:28 AM
  #43
graythang's Avatar
graythang
VENT! It's ok. Hell, I know the frustrations in dealing with Dodge and I’ll bet it’s the same at GM & Ford. They aren’t making any money and they have a boat load oftrucks on their lots with four bucks a gallon in the near future. The situation is grim so they are grim on you too. The dealers are getting crap support from the manufactures told to keep the cost down. The dealers are starting to dance the dance more then ever and it's getting ugly. Rant if it makes you feel better I don't mind because I understand.
Old Nov 8, 2007 | 01:31 PM
  #44
Altair's Avatar
Altair
Dak attack!
In your situation I think I would try finding a different dealer considering how this one has treated you. There are still good ones out there, mine back home has been great.
Old Dec 15, 2007 | 07:30 AM
  #45
coder33404's Avatar
coder33404
Last update for anyone who followed this thread. The new engine now has approximatly 1,300 mile on it and continues to be flawless. It runs smoother, has no clattering sounds at all, and is more powerfull than the original HO motor that came in my truck. The only problem that remains is the mushy shocks but soon enough we will have a good fix for that also.
Old Dec 15, 2007 | 08:14 AM
  #46
Cadillac15's Avatar
Cadillac15
Was he being serious when he said it or just joking? cus it sounds like he coulda been trying to joke with you and you took it too serious? about the passenger being the one not you
Old Dec 15, 2007 | 10:03 AM
  #47
graythang's Avatar
graythang
I'm so glad to hear that it turned out good for you. It sound like they got the problem solved with the HO.
Old Jan 25, 2009 | 07:16 PM
  #48
baddraw's Avatar
baddraw
Well guys I'm new here but I'm gonna add my 2 cents worth. Its not just a 4.7 problem, I have an 05 3.7 dak that has the same tick at startup and goes away once engine starts to warm up. Got absolutely nowhere with the dealer, "its normal" yeah right. I inherited the truck when my dad died and it had a little over 55,000 and now has 84,000 with no major issues. And they did finally fix the cruise control once I held their feet to the fire. Turned out cruise issue was a simple connector problem, you'd think that would be a starting point for their diagnosis????
Old Jan 25, 2009 | 10:11 PM
  #49
mprohr's Avatar
mprohr
Im glad someone brought this thread back from the dead. My 06 HO has the cold start diesel noise as well. Once started, it sounds normal for 10 seconds, then clatters for 3 minutes, then it is normal again. I got the truck with 36000 miles, and it has always done it. If it is normal, I've seen it explained as tight wrist pins? whatever.
Ive got problems believing it is normal. No f--in way. Could be valve lash, could be bearings. In many other threads/forums, it has been diagnosed as broken exhaust manifold bolts. Makes sense because they are completely exposed to the elements with the opening in the wheel wells. Manifolds are loose at startup and reseal when the motor warms. That has never been brought up in this thread.
Any NEW info??? If it's manifold bolts, great. Im getting headers to go along with the almost new 3" hi-flow cat and magnaflow muffler I've inherited. If its in the motor, I've got to put the money there instead.
I know I could just go out and start tearing into the manifolds to find out, but its really cold, I've got 2 kids under 4, a sick pregnant wife, and an hour heavy job. Not bitching, just explaining. I should post Shrp's suicide gun here.
Old Jan 26, 2009 | 09:22 AM
  #50
sdsdsd's Avatar
sdsdsd
OIL dripping down change to synthetic. What BS do they think you're stuppid?
