IMPORTANT!! Monroe front struts now available for 2005 Dak.
Old May 2, 2008 | 04:16 PM
  #21
graythang's Avatar
graythang
Default RE: IMPORTANT!! Monroe front struts now available for 2005 Dak.
I had been reading that some owners of the 08s feel the front is stiffer and some say too stiff. I drove a 08 TRX-4 couple of week’s ago when I was at a dealer for a part and honestly it road just like my 07 TRX-4. They say the shock part number is different for the 08. Well yes it may be since it is for a different model year and it’s OEM. The shock may be the same but with an updated demark for the model. They say the spring rate is 20% stiffer. Maybe but I could not tell the difference. Look at the factory service manuals and the front ends are identical as far as the illustrations and the nomenclatures. If there is a difference it may be with the non TRX-4 suspension. I would wait until more 08 input is found before I would look into trying OEM 08 front shocks. I was never a Monroe fan but at least it’s a change that’s got to better than stock.
Old May 2, 2008 | 06:36 PM
  #22
djsilver's Avatar
djsilver
ORIGINAL: luvmydak
ORIGINAL: Shibby927
So these will fit my 06 2WD 3.7L? How hard are these to install by yourself? Do these come with shocks?
What do you mean do they come with shocks?? TheseARE your front shocks. Not sure if they will fit '06. Monroe's website shows the #71100 struts up to '05. Contact to check on your application e-mail:GSoutherland@Tenneco.com As far as self install is concerned, unless you have installed struts before I would recommend you havea reliable mechanic do it. It is NOT a simple swap out.
The front springs on the Dakota are about 500lb/in. The JCWhitney/Ebay/PepBoys/Chinese spring compressors are not sufficient for this. You'll need either an industrial quality set of spring compressors or take it to a shop with the floor or wall mounted hydraulic spring compressors.
Old May 5, 2008 | 11:35 AM
  #23
ssenay's Avatar
ssenay
Do these fit a 2006 quad cab 4wd? i called monroe they said they will on a 4wd.
Old May 5, 2008 | 12:38 PM
  #25
rick4dak's Avatar
rick4dak
Shockwarehouse called and said the shocks are on backorder again. This time for 2 weeks. I guess after waiting for more than a year, 2 more weeks is no big deal.
Old May 14, 2008 | 10:11 PM
  #26
bkjtimp's Avatar
bkjtimp
So what's the latest word on the Monroes? Anyone got em yet?
Old May 14, 2008 | 11:32 PM
  #27
luvmydak's Avatar
luvmydak
Latest info from shockwarehouse is backordered till May 28th.
Old May 16, 2008 | 07:29 AM
  #28
rick4dak's Avatar
rick4dak
When I was at O'Reilly Auto Parts yesterday, the parts guy looked them up - they have them for $90 each and can have a set in 3 hours. I guess Monroe is supplying parts chains before shockwarehouse.
Old May 28, 2008 | 07:44 AM
  #30
rick4dak's Avatar
rick4dak
Shockwarehouse called yesterday and asked if I still want the Monroe shocks. They are ready to ship them. Of course I told them to ship them. Maybe they'll be here soon.
