tow hooks problem
Old May 1, 2008 | 06:19 PM
BAdassR/T's Avatar
BAdassR/T
Default tow hooks problem
so the last 2 days i have been trying to remove these tow hooks, yes someone has bought them, they wont come off ive tried everything but an impact wrench, the problem seems to be theres a rubber piece then a allenkey thats 1/2 big which i went and bought and still wont come off, anyone take them off and have this problem?
Old May 1, 2008 | 07:29 PM
DakSport's Avatar
DakSport
Default RE: tow hooks problem
Dude...good luck. I had to take the bolts of to mount the brackets for my bull bar. It took two grease monkeys i work with, an impact and about 3 hours to take them off. It was a biatch.
Old May 1, 2008 | 07:50 PM
BAdassR/T's Avatar
BAdassR/T
any suggestions?
Old May 1, 2008 | 09:15 PM
superdak05's Avatar
superdak05
go to the local garage and have them cut the bolts out with a torch. you may ruin the bolts, but the cant be that expensive
Old May 1, 2008 | 09:33 PM
BAdassR/T's Avatar
BAdassR/T
ah i can go next door to do that but i can do that thanx for suggestion
Old May 2, 2008 | 08:30 AM
rookie's Avatar
rookie
you might try a little heat first. heat it up to about 450 degrees and then whack on it with a hammer and try to turn the bolts either direction to break them (loose, not off).
Old May 2, 2008 | 09:38 AM
donkeypunch's Avatar
donkeypunch
King Jackass
Badass,
I ran into the excact same problem you did. Get some PB Blaster from your local autoparts store and saturate the exposed bolt threads inside the rubber boots. These are located under the hood to the right and left of the radiator. Try not to get any on the underside of the boot, just the bolt. Take a good impact to it. It will come out.
I tried to just get those long bolts out with my hand rachet, air rachet, etc. Nothing worked untill I got an impact on it. PB Blaster aids in easy extraction.
Old May 2, 2008 | 03:57 PM
BAdassR/T's Avatar
BAdassR/T
alright thanks alot im gonna try tomorrow, those things are so dum idk why there such a pain the ***
Old May 2, 2008 | 04:56 PM
Altair's Avatar
Altair
Dak attack!
Soak the bolts down with PB Blaster tonight then again before you go at it, it should work itself in a little overnight and make it easier.
Old May 4, 2008 | 01:28 AM
Nocturnal's Avatar
Nocturnal
Good Luck.
I took mine off today to put a body lift on. I fought with one of them for almost an hour with PB Blaster and a 600 ft pound impact. At the end of the hour and no progress made I got out the die grinder and cut the heads off of the s.o.b.'s.
