trailer harness wiring
Old 01-13-2009, 04:03 PM
rookie's Avatar
rookie
rookie is offline
Default trailer harness wiring
is there a cheap or easy way to hook up a trailer wiring harness if you don't have it from the factory (no tow package)?
Old 01-13-2009, 04:07 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
yeah, any auto parts store sells the little "crimp on" wiring kits. Take you all of about 15 minutes to install it...
Old 01-13-2009, 04:28 PM
cramerica's Avatar
cramerica
cramerica is offline
You can get the 4 pin kits for brake/turn/running lights for about $40 that use stock fittings to couple into the brake light lines. That's what I have. Clean, waterproof, can be installed/uninstalled in 20 mins. If you need electronic brakes, you'd better break out the wallet. I think the Mopar 7 wire harness kit, that comes with the tow package, is about $180.
Old 01-13-2009, 11:46 PM
Baby_Ram's Avatar
Baby_Ram
Baby_Ram is offline
Well you can get the 4 pin one from any auto store or walmart. I was stupid and bought mine off ebay. turns out the same harness is use on the dodge caravans i think lol.
Old 01-14-2009, 12:56 AM
gristle's Avatar
gristle
gristle is offline
I've been trying to buy one of the factory Dodge kits, however Dodge in their infinite wisdom stopped making several parts for the -01 Ram trucks and this is one of them. Argh.
Old 01-15-2009, 06:08 AM
rookie's Avatar
rookie
rookie is offline
thanx, cramerica, where did you get yours? (flat 4)
Old 01-15-2009, 06:51 AM
Cuban11182's Avatar
Cuban11182
Cuban11182 is offline
Old 01-15-2009, 11:34 AM
cramerica's Avatar
cramerica
I have that T-One connector. Works fine. Again, no brakes...just lights.
Old 01-15-2009, 01:19 PM
donkeypunch's Avatar
donkeypunch
donkeypunch is offline
King Jackass
I have an ST...that did not come with a tow package. I bought the factory harness and installed it my self. (It is NOT plug and play, like advertised). You plug in the main section up close to the driver's side front wheel. Then you have to cut a wire in the harness and splice it into the existing harness. It comes with the 7-way round connector and 4-pin flat.
Quick Reply: trailer harness wiring
