erratic idle
Old Jan 26, 2009 | 12:12 PM
white26golf's Avatar
white26golf
Default erratic idle
It seems my truck has started to idle erratically lately. After it has warmed up it tends to idle between 600-900 rpm constantly changing. Hopefully this is an easy fix, and one that I can do. If you have any ideas please respond with the possible problem and how to fix it. Thanks for your help guys.
Old Jan 26, 2009 | 12:23 PM
coondog05's Avatar
coondog05
TPS sensor....105 bucks. you can try to remove it and clean it, but probably needs to be replaced...
Old Jan 26, 2009 | 12:24 PM
OneBadKota's Avatar
OneBadKota
x2 for the TPS.
They sure got expensive. ;-o
coondog05's Avatar
coondog05
oh... its the little sensor on the side of the t.b held on with two torx screws with a 3 wire harness attached
Old Jan 26, 2009 | 12:25 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I would have guessed the same thing... its what conrtols the idle.
Old Jan 26, 2009 | 12:43 PM
white26golf
Cool, sounds pretty easy. I am currently in Germany, so it may take a while to get a new one over here. I have a Fastman TB, so I know how to take the TPS out, but what do I need to clean it with. Just to get by until I can get a new one. Oh and I have it listed as 42 bucks from Dodgeparts.com. That should make it a little easier on the wallet!
Old Jan 26, 2009 | 05:36 PM
coondog05's Avatar
coondog05
just spray tb cleaner in the hole and on the sensor... thats a good price...i needed mine asap so i must have got hosed by my local dealer.... as usual! hahaha
Old Jan 29, 2009 | 12:12 AM
Jaded's Avatar
Jaded
Hmm, bet this is my prob too. having an intermittent problem where idle jumps to 2,000. then falls back to norm.
Old Jan 29, 2009 | 02:50 AM
Mahadigus's Avatar
Mahadigus
what you want to clean is the iac motor or idle air control motor this is what really controls your idle not the tps. This is a common problem with all dodge vehicles when the throttle body gets dirty the idle with act up. remove the single torx screw holding the iac motor in place and its a bit of a pain to get in and out due to the large o-ring. Just get some throttle body cleaner and spray the heck out of it. I even use an old tooth brush to help get the carbon deposits off. Then spray it with compressed air and re-install. also try a battery disconnect for a solid 10-15min so your pcm will clear all adaptive memories. the iac motor has one and its a good idea to reset it.
hope this helps
Old Jan 29, 2009 | 08:07 AM
white26golf
hope this helps
This is exactly what I did once I took the TB off and realized that couldn't really clean the TPS. I might need a new air filter, because my TB and IAC was dirtier than I thought it should be after replacing the TB and cleaning the IAC about a year ago. Back to the point, not only did this fix my idle problem, but I also gained back 2mpg and the truck seems to hold speed better going up hills with the cruise control on. I will definitely have to remember this when I start to experience these problems again or have a drop in fuel economy.
