Towing questions!~
Towing questions!~
Hey ya'll long time no forum. I've been in Qatar! Yaayyyy- not. ANYways. I'm finally getting married! But I gotta move a ton of stuff via Uhaul from VA to NE in a 6X12 pull along trailor. SO, is this possible with just a ball hitch? Because I see these towing harnesses for over 150 bucks and I hope I don't need that. I also don't know where the wiring is. I know Uhaul will help with this but I would rather be somewhat educated before I go in and look foolish, and you veterans already know I'm foolish so help?! Thanks boys.
trucky,
Do you have the 4.7? What gearing do you have? I towed the 6x12 with about 6,000 lbs but it was southern NC to norther NC. I agree with edsham that you need a hitch. I just moved myself, partial DiDty mostly HHG. Anyway, you're going to get reimbursed why not just rent a large penske truck and a car dolly and tow the truck or have the fiance drive it.
When we left, I had the second smallest Penske truck and a car dolly for my wife's jetta. Towed it all the way down to FLORIDA.
Hey fellow Air Force (I am a Loadmaster) been to Qatar quite a bit and everywhere else in the AOR for that matter.
Whatever you buy to move your stuff, even hitches, towing equipment, trailer rentals... Its all covered by the PCS move. Keep your receipts and they will pay for your new tow toys. Get a receiver and hitch done right and its free, so get the good stuff (not uhaul). You will need the harnesses as well.
You should be able to tow just fine with most combo's of engine and gearing but if you are V6 dont go over 4800 and you are V8 dont go over 6800 lbs. There are more specifics if you go to http://www.dodge.com/hostc/towing/guide.do
Load Clear
Load Clear
Welcome home! One of my best friends just got back from the IZ. I bet you are glad to be back.
Yes, get the factory hitch and wiring harness...you will thank yourself later. The factory unit is easy to install, but the wiring harness will give you a little bit of trouble. It is still relatively easy, just a little time consuming.
I have towed a U-Haul twin axle vehicle transport a few times. The trailer weighs in at 2600lbs. With the Talon on there, I was at 5300lbs combined. With the Monte Carlo, I was at 6100lbs combined.
My truck is an ST 4x4 QC with the 3.7L and 6-speed. So, I would say that I was a little over what is recommended for my truck. The coolest part about towing those cars was, it was easy. I never felt like I was on the edge of safety. Also consider that I do not have a brake controller installed either....Even with the Monte on there, the truck stopped with no problem. I would not hesitate to tow these cars again...
on
1 Post
Welcome back Trucky! You'll definitely need the hitch and harness for the 6x12, the bumpers aren't rated to tow all that much and I probably wouldn't even put as much as they're rated for on there. In general those things are for towing small light trailers once in awhile, any real towing and you want to step up to a real receiver.
Trending Topics
Nothing wrong with a UHaul reciever and hitch. Anything you buy will be bolt-on anyway.
My 4 Pin wiring harness was about $40 and plugs into the rear tail light wiring with stock-style snap fittings. I pulled a packed UHaul 5x10 for 900 miles no problemo.
Not sure if the 6x12's have surge brakes, but be careful slowing down even if they do.
