Looking for Brake Replacement Recommendation
Hi Everyone...Can't say enough about all the contributions here.
I am an original owner of my '05 Laramie and have many of the most common problems. Most notably, and forever will leave a bad taste in my mouth over 7 attempts to correct, is the infamous Vibration problem. Before hitting 8K miles, 4 different sets of tires, 2 sets of replacement wheels, TSB performed and on and on, still only 90% fixed and vibrations occur at 68 MPH.
But, enough whining.
I just need a couple suggestions on rotor and pad replacement. I am a believer that you get what you pay for and I want something slightly better than OEM, but it does not need to be high-performance. Average+ and good reputation brand is what I am looking for.
A few suggestions that have worked well for people would be appreciated.
Thanks much,
Michael
Thanks much,
Michael
on
1 Post
check out r1 concepts man...they're rotors a for a good price..2 for $125 Slotted and Cross drilled....http://store.r1concepts.com/Items/It...ne%20-%20Front
And if u want pads they have some too but ssbc makes good ones as well....
Ditto on R1
As for the vibration, if it has been a long time since you had the TSB done, take it back and have it performed again. In some instances, bad parts were replaced with bad parts. I think it has all been straightened out now. Maybe take it to a different dealer. Look for the M on the axles yourself.
Thanks,
LB
on
1 Post
The most notable advantage is they have an increased surface area to allow better cooling. Other advantages include lower rotational mass, better off-gassing properties, and increased wet performance.
Guest
Posts: n/a
i just put my brakes on thursday. i went with performancebrakes since i got my lotted dimpled rotors for 2and some change with free shipping. keep in mind that shipping isnt going to be cheap. the rotors weigh close to 40 pounds. got free semi metallic pads with mine also. (i sm on my phone righ now or i would post pics and link...) i will get a pic up tonight when i get home from work.
Thanks for the responses.
Snipingdude, R1 concepts looks like a good deal for a better product and seems like a frontrunner. Their pad price/quality seems reasonable as well so I may just get the bundle from them.
One last quick question for you guys that have changed your fronts. I'm changing mine because I need to with 35K miles, but would you recommend I check the rears, or is it a low-risk gamble that I probably don't need to worry about checking them, say until 50K miles?
Thanks,
Michael
Thanks,
Michael
Trending Topics
Guest
Posts: n/a
i didnt have to change mine yet... i am at almost 60k. i cleaned them up with some brake clean and air.. it doesnt look like they get a lot of real use. i am guessing they dont handle much of the braking dutys.
**Edit**
Here is a pic of the new rotors and calipers I just put on... I went with the free semi metallic pads that came with the rotors...
I got my rotors and pads from here.
I got new calipers because the drivers side tore up an o-ring when I was backing off the pistons...
I went to napa for the calipers...
**Edit**
**Edit**
![](http://i172.photobucket.com/albums/w37/ericemery/truck%20stuff/IMG_0071.jpg)
**Edit**
![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
