Big Time Power
Old Apr 27, 2009 | 10:46 AM
  #51
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Awesome work Blown! I think you give a lot of members hope. You truly have a badass truck! I agree with ya being the only one out there, I havent seen many worked up 3rd Gens. Hell at most of the shows I have only seen one or 2. Now 2nd Gens and 1st Gens there are tons, on top of the Rams.
Good Work!
Old Apr 28, 2009 | 07:35 PM
  #52
Blown287's Avatar
Blown287
Thanks alot guys, one of the reasons I chose this project was our generation and newer have been overlooked by alot of the aftermarket big names. By far, I did not take this project on alone. I get alot of wisdom and advice from the guys over on dakota-durango, I had advice from Hemifever and some friends that work on imports.
Old Apr 28, 2009 | 08:51 PM
  #54
Blown287's Avatar
Blown287
Originally Posted by ericemery
Do you mind if I ask what size injectors you went to? and did you replace the fuel pump with a wallbro?
Still using the stock fuel pump, i went with Ford SVT 39# injectors.
Old Apr 28, 2009 | 09:12 PM
  #56
Blown287's Avatar
Blown287
Thats awesome.... will you need a fuel pump for the boost levels your going for?
I think Richie on bionicdodge is still running his stock pump so I should be ok. If I go over 15lbs of boost, I will probably beef up the fuel pump also.
Old Apr 28, 2009 | 10:31 PM
  #58
Blown287's Avatar
Blown287
I would shoot Hemifever an email and ask him what you want to do. He has tought me 90% of everthing I know about boost.
Old Apr 29, 2009 | 06:48 AM
  #59
snipingdude's Avatar
snipingdude
Have you clocked a 0-60 time yet man?
Old Apr 29, 2009 | 09:36 PM
  #60
Blown287's Avatar
Blown287
Nope, but I will this next week when I get back. We have used a measuring wheel to mark 1/4 miles distances and made a coulple of dry runs. Once I finish with the mounts and alcohol, I'm going to ensure everything is good to go.
