$1000 Supercharger?!
Old May 2, 2009 | 10:21 PM
baracis's Avatar
baracis
Default $1000 Supercharger?!
With the Air Ram adapter kit (http://airram.com/product.php?catego...productid=1297) that allows us to put a 4.6L supercharger on our engines, would there be any way to make something like this work? I know it specifies 03-04, but those superchargers are way more than an STS turbo setup.
http://cgi.ebay.com/ebaymotors/POWER...#ht_500wt_1379
Old May 2, 2009 | 11:57 PM
baracis's Avatar
baracis
What about this one?
http://cgi.ebay.com/ebaymotors/Power...#ht_645wt_1364
Old May 3, 2009 | 12:42 AM
BAdassR/T's Avatar
BAdassR/T
Originally Posted by baracis
i know this guy thats for a 5.9 R/T or the 5.2.. as of the first one not sure, i do know if u want to try and get a hold of a cobra supercharger eaton, airram is working on that to get that to bolt up to our motors..
Old May 3, 2009 | 01:04 AM
Blown287's Avatar
Blown287
Hopefully it won't be too much longer. There is alot of excitement about the whipple/eaton project. I'm sure once Airram get back from the sandbox he will wrap up the project and get it out.
Old May 3, 2009 | 07:22 AM
superdak05's Avatar
superdak05
dont forget, everything airram is making is for the ram. and the only reason i say this is because of the hood clearance, make sure when you close the dakota hood, you have plenty of room, which the ram does.
Old May 3, 2009 | 02:31 PM
mikset's Avatar
mikset
If Nick can make that project fly, it'll open up a whole new world for us 4.7 guys. Guess we'll have to wait and see about clearance issues on the Dakotas.
Off topic I know but you guys (superdak05 and blown287) have 206 cams on your trucks. Did you guys look into the 212 cam before you got them or was it a tuning issue at the time? I know a high stall converter is recommended with the 212 and I just got my 2600 converter Friday, hopefully get it installed next week. I've already got an SCT. Thinking about which cam I should go with.
It's a bitch though because 4.7 cams are on back order because of comp cams restructuring issues.
Old May 3, 2009 | 03:19 PM
superdak05's Avatar
superdak05
as for the 212 cams, we did not have any tuning yet, now with the sct tuning, i believe it will be ok now, might need larger injectors with those cams, or throttle body
Old May 4, 2009 | 10:47 PM
Blown287's Avatar
Blown287
With the 212s you will need the lashcaps, beehive springs and definately need tuning. You already have SCT so you should be good to go. The install isn't too bad, I used the Haine's manual with mine.
Old May 4, 2009 | 11:39 PM
Blown287's Avatar
Blown287
Originally Posted by superdak05
the only reason i say this is because of the hood clearance.
LOL, for a Whipple, I would find a way to raise the hood. That is the good thing about the R/T hood/scoop combo, always room to cut a hole.
For the cam questions, this was posted on dakota-durango.
http://www.krcperformance.com/krc/in...d=37&Itemid=62
