Quivering Truck
Old May 4, 2009 | 03:47 PM
cramerica's Avatar
cramerica
Default Quivering Truck
This is a problem I've had for a couple thousand miles now. I'm finally getting sick of it, particularly now that the truck just ticked over 35,000.
At any speed between about 50 and 60, the truck will quiver / shudder. Fairly high frequency, about as fast as you can drum your fingers on a table. I can feel it and see it, espically in the CB antenna. Bumps can start it quivering, but sometimes it just comes on. Other times, the truck rides smooth as glass. Go around a turn, and it can either come on or go away depending on what it was doing before the turn.
Sometimes it's minor, sometimes, it shakes hard enough to really **** me off.
That all leads me to believe my tires are still unbalanced. They are not stock, and this never happened with the stockers. Corners get the wheels spinning at different RPM, and maybe a couple of them are unbalanced and 'sync up' at certian speeds and start shaking.
I've had them balanced before, but I think now I am going to go to Sears and have them take the tires off the rims, and reinstall them on different rims, and completely rebalance them.
Hopefully the Sears plan works out. Any other thoughts?
Old May 4, 2009 | 04:19 PM
biker_ahoy's Avatar
biker_ahoy
I put after market tires on my stock rims and the shakes kept coming back it's been rebalaced and rotated about 4 times now. since the last one I haven't had any issues but ya I know what you mean. I had it really bad the last time and since telling them and getting it all done again it's been good. I believe it has somthing to do with the rims or at lease mine the last time they balanced they used the fingers instead of the single center nut if that makes any sense. I sure someone can explane it better Than I can.
Old May 4, 2009 | 04:21 PM
mprohr's Avatar
mprohr
How many miles on the new tires? How many miles has it been since your last balance? Were they fine after the last balance? Did you get an alignment? Have you tried re-tourqing the lug nuts...in sequence...to proper spec? You may have thrown a weight. You may have shiddy tires. The rear axle/brake tsb may be coming on...but I doubt it. Your brakes may be shot, warped rotors/drums. Good luck.
Old May 4, 2009 | 06:34 PM
baracis's Avatar
baracis
Same thing here at high speeds with my MTs man.
Old May 4, 2009 | 09:13 PM
cramerica's Avatar
cramerica
I doubt any brake or axle issues. It's an 07, and with 35K on the stock brakes, they are still perfectly smooth. I downshift alot and generally don't drive like an idiot, and I think that helps.
It's the tires, or possibly rear shocks are completely blown out, and do nothing to restrain the rear axle. Hopefully completely unmounting the tires will fix it.
Old May 4, 2009 | 09:20 PM
baracis's Avatar
baracis
I completely unmounted my tires and to be extras sure I sprayed the brakes down with cleaner, and cleaned up everything i could get my hands on really.
Old May 4, 2009 | 09:21 PM
mprohr's Avatar
mprohr
Good point. Get Ranchos.
Old May 4, 2009 | 09:37 PM
baracis's Avatar
baracis
shocks in the rear are supposed to stop shaking in the front at high speeds?
Old May 5, 2009 | 06:37 AM
sdsdsd's Avatar
sdsdsd
There was an issue with the clips that hold the rear brake drums in place for factory use. If you still have the clips on your rear brake drums, remove them and re torque to wheels. Hope that helps you.
