Fan Removal
Old Jun 2, 2009 | 03:52 PM
baracis's Avatar
baracis
Default Fan Removal
I need some advice getting that damn fan off to put my efan on. PB blaster didn't help. Advice please!
Old Jun 2, 2009 | 04:06 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Bust a knuckle or two and make your self pissed off? That usually helps
Old Jun 2, 2009 | 04:15 PM
Cuban11182's Avatar
Cuban11182
Take some vice grips and grip the pulley near the top so that the stud that sticks out hits against the vice grips to hold it while you turn the nut.
Old Jun 2, 2009 | 05:08 PM
baracis's Avatar
baracis
I'm sitting at work trying to visualize this. Could you reword that please? I'm gonna tackle this tonight. No sleep til it's done!
Old Jun 2, 2009 | 06:35 PM
Cuban11182's Avatar
Cuban11182
Here you go, you will see the stud sticking out from the engine, that will hold the pulley still.
Old Jun 2, 2009 | 06:45 PM
baracis's Avatar
baracis
Thanks man.
Old Jun 2, 2009 | 06:50 PM
fastyz400's Avatar
fastyz400
Yes, vice grip worked for me. I tried the strap wrench, that didn't work.
Old Jun 2, 2009 | 06:59 PM
baracis's Avatar
baracis
Sweet. Good to know. Thanks fellas. If this doesn't work I'm using my f*cking shotgun.
One other trick I did learn about to day was tap it with an airhammer. I'll PB it again, tap it with my airhammer a few times, and use your guys' trick.
Old Jun 2, 2009 | 08:43 PM
Cuban11182's Avatar
Cuban11182
no problem. good luck
