Cylinder 1 misfire?
Old Jun 30, 2009 | 12:54 PM
snipingdude's Avatar
snipingdude
Default Cylinder 1 misfire?
Havent gotten this before, read it through my superchips tuner...can someone lead me in the right direction lol?
Old Jun 30, 2009 | 12:56 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Bad plug? maybe bad gas?
Old Jun 30, 2009 | 01:32 PM
snipingdude
hmm i thought about plugs...idk about gas ill see lol...
Old Jun 30, 2009 | 02:35 PM
lghtngblt02
I would guess its something with the plug first. Is it quiver and or skipping alittle?
I have had a plug crack the porcelain from the inside before on my Phuckus. For the life of me I couldnt figure it out cause the plugs were practically new in it, the injector was fine, fuel filter was changed out, gas was ok and nothing was curing it. I finally had the dealer run a detailed diagnostic test on it and they told me it was a crack in plug of the cylinder that was missing and wanted to change the plugs. I said nah, I brought it home changed out the plugs an voila, runs great still!
Old Jun 30, 2009 | 02:40 PM
cramerica's Avatar
cramerica
lol lol
Old Jun 30, 2009 | 02:48 PM
lghtngblt02
Yeah talk about dumb move... should have just changed the plugs out again. Instead they were like $85 plugs by the time you count the diagnostic costs and the 4 plugs...BAH o'well
Old Jun 30, 2009 | 04:11 PM
Blown287's Avatar
Blown287
Snipingdude, have you been running any type of advanced tuning?
Anything more aggressive maybe? The Chrysler 4.7L coils are not the strongest coil ever made. A little change in tune or aggressive vacuum can flip a coil code for misfire.
Old Jun 30, 2009 | 05:13 PM
snipingdude
hmm no man nothing really...nothing but the 87 tune from Superchips with the limits set to max...any idea on a fix???
Old Jun 30, 2009 | 06:33 PM
Blown287's Avatar
Blown287
That could very well be it. I would return to stock, clear your DTS codes and try it like that. Every once in a while I will flip that code and its usually vacuum pressure on the coil. If it pops back up in stock, then I would shart checking plugs(and caps) coils ensure the wires aren't pinched etc.
Old Jun 30, 2009 | 08:09 PM
LB's Avatar
LB
Yup, I had that and the dealer replaced the coil.
LB
