One more thermostat question
Old Jun 8, 2010 | 09:52 PM
  #31
rengnath's Avatar
rengnath
Originally Posted by sullysdetailing
How about the stat?
Sully,
Plugged in the info for both a 3.7l Dakota and a 4.7l Dakota in to Autozone and looked up a thermostat and both take the same part number. So if Autozone's website is accurate, which I would highly hope so, then they take the same stat.
Old Jun 9, 2010 | 08:01 AM
  #32
sullysdetailing's Avatar
sullysdetailing
Originally Posted by rengnath
Sully,
Thanks Buddy Now I am off the get a 180 degree stat. To anyone running the jets stat did you have to mod the stat to get it to fit?
Old Jun 9, 2010 | 09:04 AM
  #33
rengnath's Avatar
rengnath
The jet stat is a direct fit, however $30 is overpriced.
Old Jun 9, 2010 | 09:16 AM
  #34
hendrixx324's Avatar
hendrixx324
very over priced. I regret paying it
Old Jun 9, 2010 | 12:24 PM
  #35
ozone45212's Avatar
ozone45212
Hey ozone,
I saw your post earlier and forgot to respond. You want to gap them to .042" per:
This is found on page 3 and page 10 on this thread:
https://dodgeforum.com/forum/3rd-gen...ark-plugs.html
Very interesting read and it discusses some useful information, expecially on how autolite rates their plugs and their input on the 3923 plug for our engines.
Thank you for the reply! I guess I know what I will be doing this weekend!
Old Jun 10, 2010 | 01:35 AM
  #36
ozone45212's Avatar
ozone45212
Talking
ok, now I have the plugs and stat. Anyone give me an idea of how long this will take me to install the plugs and stat? 3.7L V6
Old Jun 10, 2010 | 11:01 AM
  #37
popsnbeer's Avatar
popsnbeer
plugs should take about an hour. They are pretty deep in the engine and require quite an extension! I think I had two 10" extensions on there for a few of them!
The stat is pretty easy and should take about 30-45 minutes if you do it right. I would also get yourself some new fluid instead of putting the same old stuff back in it.
Edit: just saw that you have the 3.7 (not the 4.7). I can't speak to that one. I assume it's pretty much the same thing, but two less plugs and hopefully a bit easier to get to :-)
Old Jun 10, 2010 | 01:27 PM
  #38
ozone45212's Avatar
ozone45212
wow, looked at the manual and under the hood, and spark plugs look a little more involved than just taking off the wires and pulling the plugs! Looks like once I take off the cai and thecoil bracket/ coil wires the plugs should be reachable. What were they thinking? Take me back to the dealer?
Old Jun 10, 2010 | 03:47 PM
  #39
rengnath's Avatar
rengnath
Its really not that involved. You will have to remove the intake though, and I also had to move the coolant lines and the brackets that hold them (they serve as the mounts for the stock intake hat). I did one plug at a time to avoid mixing anything up. Remove the wires, remove the small single bolt holding on to the coil and pull straight out. Take compressed air and blow out the hole to remove any debis. Take your 5/8" socket (I used a spark plug socket that will hold the socket to actually remove it) and loosen it up and pull out the old spark plug. Gap the new plug, put it in the socket (youll need a way to hold it in the socket if you choose to not get a sp socket) and apply the antisieze. Put the new socket in and they are rated to be torqed at 20 ft lbs. On the coil I used to silicone grease around where the boot attaches to the plug and around the gaskets to prevent mositure from getting in. Slide the coil back in, bolt it on and reattach the wires. You will need at least a 10" extention to do the job. Took me an hour and 15 minutes so not too bad.
Old Nov 30, 2010 | 12:16 PM
  #40
batfink0's Avatar
batfink0
OK... Here's my question guys...
What is the factory Thermostat rated at?
I'm guessing you are all from the States and trying to lower the rating of your thermostat in order to run cooler, but I'm from Canada and want the opposite. I need it to warm up faster and stay warmer in the winter.
I'm guessing a 180 isn't what I'm looking for. I can buy a 195, but maybe that is what the factory has in there already... Thoughts?
