help!!!
#31
just because the water was up to my tires doesnt mean its going to be in the engine compartment. if you were to roll the windows down, and roll a truck into a lake, it will float for a while. there are areas that will trap air (ex. engine compartment), and will take a little while to sink.
#32
right. The cowl/grille/headlights/fenders are just big vents for the engine compartment. The engine compartment has no pressurizing capacity what so ever.
#34
never tried to say the damn thing is water tight, but water isnt just going to fill into the engine compartment. you guys keep saying i got water in the motor, and i am saying it didnt. there was not even a sign of mist in around where the filter was at. even if there was presense of water drops, it would still have to get a decent amount past the filter.
if water was the reason it messed up, why didnt it cause an issue while i was trying to cross? not 2hrs later??? the only thing i can think of is that i got water in the fuel and was causing lean conditions. if that is the case, then i can see why it messed up down the road when i was getting the motor over 2400rpms.
#35
ok, lets use some common sense here.
the cowl does not vent the under hood. there is a seal on the cowl to keep the outside elements out as well. if the cowl were to vent the under hood heat, then there would be a lot of cracked winsheilds in the winter from the heat. if you open the hood, you see the heat radiating off the motor, do you see it from the cowl? no.
air enters thru the grill, the inner fender into area for like the stock air box air box, the lower air dam on the bumper if applicable, etc. there is no air movement areas (dead air) in areas like the back of the engine compartment, wheel wells, etc. so where do you think all the air goes when driving, crawling, sitting at idle, etc? it radiates out from under the truck.
now me making the crossing thru the water will block the large volume of underhood air from going out underneath the truck. air will escape thru small areas it has that is can till the pressure is equalized. the fan is still pulling air into the engine compartment and has no where to go and this will tend to cause some bouyancy till an area is found for all the air to escape or the method of outside air is stopped/vented into atmosphere.
now for the people that think i am being unreassonable, stubburn, stupid, etc. give me your reason to think i am wrong. i have raced, 4-wheeled, built, etc for a while. this isnt my first time to break something.
#36
#37
