Quick question that's bothering me...
Are you referring to a stall converter? If so, this is just a misused name for a torque converter with a higher than factory stall rating. Torque converters are only found on automatics (does the same job as the clutch in a manual). The stall rating is basically the rpm that the torque converter can safely be ran up to without the vehicle moving.
Trending Topics
Ohhhhhhhh...... ya stall, not still... haha
Got ya... thanks dude...
But if it does the same thing as a clutch...
...if, let's say, you have a 2700rpms stall converter, and I have my clutch in, revving to 2700rpms, and I let out the clutch, it'll burn the clutch, unless I dump it, where then, I'll just spin... so therefore, a stall converter is better for higher rpm launches?
Correct?
Correct?
