engine wont turn over
Old Aug 15, 2009 | 08:52 PM
utexasrick's Avatar
utexasrick
Default engine wont turn over
so all of a sudden I'm having trouble starting my engine. It worked fine last night then this morning it wont want to start. So when I turn the key the engine trys to turn over but it seems to get stuck, so it moves a little then stops, then moves a little more. I thought it could have been the starter but I took it off and had it checked out and it works fine. So what I'm think is it might be one of the accessorys that is seizing up. What I want to do is take off the belt and turn over the engine to see if it turns over easy, but I dont know if that will harm the engine. any advice, anyone ever have this problem?
Old Aug 16, 2009 | 05:34 AM
Cuban11182's Avatar
Cuban11182
Battery?
Old Aug 16, 2009 | 12:04 PM
utexasrick's Avatar
utexasrick
well that was the first thing I thought but everything else works fine, radio, ac.. so I'm pretty sure thats not the issue
Old Aug 16, 2009 | 01:52 PM
utexasrick's Avatar
utexasrick
well I checked to see if any of the accessories were seized up but they all were fine, all the pulleys turn freely
Old Aug 16, 2009 | 04:18 PM
projektdirtfab's Avatar
projektdirtfab
even if your battery has enough juice to power a blower motor, headlights, or radio, doesnt mean it will have enough to crank over an engine. try using jumper cables...bet ya it will crank faster
Old Aug 16, 2009 | 04:23 PM
Cuban11182's Avatar
Cuban11182
Yea sounds like the battery is dead but still has enough juice to power accessories. You need cranking amps to get the truck started.
Old Aug 16, 2009 | 08:59 PM
Cuban11182's Avatar
Cuban11182
Oh, and double check your connections on the battery terminal. Mine wasnt turning over and the negative terminal had become loose. Worth a look.
Old Aug 16, 2009 | 09:49 PM
DakotaDoug's Avatar
DakotaDoug
Default Do you get a rapid clicking from the starter when it wont start?
Mine is/was doing the same thing all of a sudden. Headlights were strong, radio fine, even ran the windows up and down a couple times. Also cranked the engine multiple times before I drained the battery real good.
Mine jumped, but only when I completely disconnected the battery from my truck. It wouldn't jump start by just placing the cables post to post from the other vehicle.
Since then I have completely cleaned both ends and also taken the battery out and trickle charged it over night. Its held on for another 5 days, but I'm thinking the battery is on its last legs.
Old Aug 17, 2009 | 12:20 PM
cramerica's Avatar
cramerica
I had a battery strong enough to run lights, radio, everything. But the starter would barely engage and wouldn't crank. Had to jump it, and it fired right up.
