Broken exhaust bolt
Old Nov 9, 2009 | 08:54 PM
dakoduh's Avatar
dakoduh
Angry Broken exhaust bolt
So has anybody else had this happen? The rearmost bolt on the right side exhaust manifold decided to break off at the head. The truck had just reached 50000 miles. Fortunately I was able to get to it with a short angled airdrill that I borrowed from a buddy. Got a hole drilled in it & was able to get it out with an easyout without having to remove the manifold & probably break several more bolts in the process lol. I smeared some antisieze on a 10.9 bolt (they're 8mm x 1.25 btw) tightened it up & it doesn't leak and seems fine luckily. These bolts look too small & wimpy for the application in my opinion
Old Nov 9, 2009 | 09:45 PM
Blown287's Avatar
Blown287
That sucks man. I hit mine with PB blaster before going from stock manifolds to headers and I had no issues extracting the bolts. I know Viperkota broke some manifold bolts a while back.
Old Nov 10, 2009 | 08:15 AM
dakoduh's Avatar
dakoduh
What was most surprising & why it sucked was the bolt broke on the stock manifold, hadn't ever been touched by anyone since leaving the factory?
Old Nov 10, 2009 | 10:38 AM
mprohr's Avatar
mprohr
Mine did the same thing. Had a local shop replace the gasket. They also retapped the hole and installed a larger stud, as this is a common problem.
Old Nov 10, 2009 | 10:39 AM
mprohr's Avatar
mprohr
Dodge uses 8mm studs which are undersized for this application.
Old Jan 10, 2010 | 06:45 PM
ixc's Avatar
ixc
what length was your replacement bolt?
my truck has ticked since i bought it and im just getting around to looking for the leak. while changing the oil today i decided to wiggle the heatsheilds. sure enough the top rear bolt on the driver side is broken.
Old Jan 11, 2010 | 10:21 AM
mprohr's Avatar
mprohr
I would guess 1.25. Don't think you want to mess with that dimension by going longer or shorter.
Old Jan 11, 2010 | 10:38 AM
ixc's Avatar
ixc
in the original post 10.9 is the grade of bolt, 8x1.25 is the thread size and pitch. There is always a third part of the equation which is length in mm. Thanks for keeping the thread at the top
Can someone also chime in on the TQ specs for this area?
Old Jan 11, 2010 | 11:14 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Manifold Bolts: 18 FT-LBS
Heat Shields Nuts: 72 IN-LBS then turn em back about an 1/8 of a turn
Old Jan 11, 2010 | 02:49 PM
babygotdak's Avatar
babygotdak
I have the same problem on the Drive side manifold. The shop wants 350 to change the gaskets. How hard is this to do? Do I need to remove the fender and everything around it? Thanks.
