air filter direct to MAF?
Old Apr 7, 2010 | 09:47 PM
Dakkkota's Avatar
Dakkkota
Default air filter direct to MAF?
is it a good idea...and the sensor of temperature people do the power cable mod....can i leave it in a cold area out of the intake plumbing in the engine bay instead?
Old Apr 7, 2010 | 09:52 PM
hendrixx324's Avatar
hendrixx324
Idt the power wire is a very good idea, but i dont no much about it. I made one for my truck but hessitated to put it on so i just stuck with my gut and didnt put it on. I think it makes the engine run too lean
Old Apr 8, 2010 | 12:57 AM
Blown287's Avatar
Blown287
I have relocated my Air Temp Sensor into the frame away from the engine bay. Your MAP sensor is mounted at the bottom of the intake manifold and above the water temp sensor.
Old Apr 8, 2010 | 07:07 PM
Dakkkota's Avatar
Dakkkota
Default ok
ive seen a guy with a oval K&n and a RT fonctionnal ram air hood...tb seems to be a 3 inches 1/4...what filter are wou using to clear stock hood? and to relocate the wire do i really need to skin the wires and put them longer??? the power cable seems a good mod but in the future y will add exhaust im afraid to run lean what is best choise between power cable and relocated cable in a colt area?
Old Apr 8, 2010 | 07:19 PM
Dakkkota's Avatar
Dakkkota
Default map
does it need to be relocated?
Old Apr 9, 2010 | 11:47 AM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Is it wise to put the sensor somewhere where it wont read the correct air temp? Isn't that the point of the sensor??
Relocating it is pointless. It can only cause more harm then good. Why would you want to put it somewhere where it will get a "colder" reading then what the actual air temperature is??
Old Apr 9, 2010 | 11:48 AM
hendrixx324
Its the same concept of the power wire i guess... I dont like the idea but other people say they have no problem with the power wire.
Old Apr 9, 2010 | 07:42 PM
hendrixx324
so is that the same as the power wire
