CAMSWAP write up. DIY!
Old Aug 9, 2010 | 10:33 PM
  #22
Blown287's Avatar
Blown287
Airram has them but you can also try calling Comp Cams to see if they have them. Plus they show up on ebay motors from time to time.
Old Aug 10, 2010 | 12:17 AM
  #23
dakotajerry's Avatar
dakotajerry
Good write up. Looks alot easer than my chevy cam swap. No push rods or lifters to deal with.
Old Aug 10, 2010 | 01:03 AM
  #24
Blown287's Avatar
Blown287
Yes Sir. No push rods, lifters or degreeing the cam, lol. SOHC motors are much easier than pushrod motors. Just put piston 1 at TDC, and the cams are slightly out of neutral so turning them back to the correct position takes minimal effort.
Old Aug 7, 2011 | 03:45 PM
  #25
sdtalon's Avatar
sdtalon
I'm getting ready to install H/O cams and i just noticed the detail about the lash caps. Are those required? And where's the best place to get them? I only see them for 206 and greater grinds.
Thanks,
Kane
Old Aug 7, 2011 | 04:50 PM
  #26
MitsuRaider's Avatar
MitsuRaider
You don't have to mess with the lash caps for the HO cams
Old Aug 8, 2011 | 12:44 AM
  #27
sleds's Avatar
sleds
you just reuse the stock lash caps then?
Old Aug 8, 2011 | 06:17 PM
  #28
Blown287's Avatar
Blown287
The 4.7L doesn't have stock lash caps. Lash caps are an aftermarket part used for cam swaps 206 -224. They fit between the valve stem and rocker.
Old Aug 9, 2011 | 06:47 PM
  #29
sdtalon's Avatar
sdtalon
Is there a write-up like this for the 08 intake manifold? I,m having a hard time with the EGR part and I,m wondering if I need the 08 hard line as well.
thank you.
Old Aug 10, 2011 | 01:51 AM
  #30
sleds's Avatar
sleds
Gotcha, thanks Blown. Going to do this if my HO cams ever show up.
