scary moment urgent!!!
Old May 10, 2010 | 03:37 PM
canadian dakota's Avatar
canadian dakota
Default scary moment urgent!!!
im driving down hwy16 when I loose steering trying to take the off ramp I manage to fight it over to the in side shoulder I checked I have no leaks or nothing tried. tried t turn the wheel and it loosened up ten minutes later did the same thing I topped of my fluid yesterday is it possible I put to much in. its reading over full oops.. quick fix??
Old May 10, 2010 | 03:48 PM
canadian dakota
nothing I can see steering seems to fine now
Old May 10, 2010 | 08:03 PM
canadian dakota
Five hours later its still good weird..... airpocket in the fluid line maybe??????
Old May 10, 2010 | 08:26 PM
donkeypunch's Avatar
donkeypunch
King Jackass
Check your tie-rod ends. Did you accidently put it in 4x4?
Old May 10, 2010 | 08:54 PM
canadian dakota
no was in 2wd what am i looking for i was on the hwy for bout 10min only it was fine while i was in the city only noticed it when i went to switch lanes to exit. felt stiff when i dried to take the exit ramp (cloverleaf kindadeal) nothing had to fight er hard to get her over to the inside shoulder thank god i was on the inside lane tried checked for leaks nothing. tried turning the wheel it eventually loosened up what would i be looking for in the tie rods nothing looks bent.. i would have a shimmy if they where bent wouldnt i???
Old May 10, 2010 | 09:08 PM
Blown287's Avatar
Blown287
If you loose power then you loose power steering. Check your fuses to ensure one isn't loose.
Old May 10, 2010 | 09:54 PM
hendrixx324's Avatar
hendrixx324
check your belt tensionor. If the belt comes loose you lose power stearing
Old May 10, 2010 | 10:50 PM
canadian dakota
hmmm went and check belt is tight as for the fuse I checked them a couple clicked when I pushed on them I didn't note what they where for but none seemed loose. also noted that none of the fuses are marked with power steering
Old May 10, 2010 | 11:24 PM
Blown287's Avatar
Blown287
When we first bought the Wife's 07 Durango, we had a similiar moement. The entire electrical system went out, power brakes steering and all were lost. It all came to down to a PCM and fuse electrical issue.
