dakota lifted with coil over
Old 06-09-2010 | 01:02 PM
canadian dakota's Avatar
canadian dakota
ima check it out when I get home
Old 06-09-2010 | 01:15 PM
nicolash's Avatar
nicolash
Originally Posted by hendrixx324
very nice, what kind of struts are they
Are the original coil over strust but I cut it
Old 06-09-2010 | 01:20 PM
hendrixx324's Avatar
hendrixx324
oh they look totally different than mine.
Old 06-09-2010 | 03:15 PM
canadian dakota
how'd you cut and fab everything
Old 06-09-2010 | 04:29 PM
nicolash's Avatar
nicolash
what was cut over the original coil is the part that appears in the photo and I had to cut a little spring to leave the compression, but the coil over is toytec with the original part of the stock coil over
Old 06-09-2010 | 04:59 PM
canadian dakota
so the coil/spring is mopar and the shock is toytec? am I understanding you correctly sorry im on my phone at work and the pics don't come through very clear I need an Iphone lol
Old 06-09-2010 | 05:18 PM
canadian dakota
and what about the cv's they look like they're at a pretty narly angle to how much you spend on this and how many hours
Old 06-09-2010 | 07:21 PM
nicolash's Avatar
nicolash
the coil over is complete toytec only thing he did was add the piece below, and also cut some springs.
In the more I delay in the installation was about 5 hours.
The angles I will arrange with limit straps
Old 06-09-2010 | 08:36 PM
canadian dakota
ooooooh k now i see it you cut the end off the stock strout welded it to the new strut and used the stock coil hmmmm how well will these welds hold under some airborn muddbuggin like a certent raider guy we know lol its a nice set up... i just dont understand what you mean by limit straps
Old 06-09-2010 | 09:01 PM
nicolash's Avatar
nicolash
angles problems occur when you stretch the suspension then I will put some limiters so they do not stretch much, and with the compression that has the suspension will be the same heigh
Quick Reply: dakota lifted with coil over
